?Clutch Help!
Old Jun 18, 2005 | 07:08 AM
96mAx2fast's Avatar
?Clutch Help!
I recently started feeling that my clutch feels alittle notchy when im taking of in first gear or when im shifting gears while at a complete stop. Also, when i take off slowly the car tends to shake. That has never happened to me before. Can someone help please?
Old Jun 18, 2005 | 07:17 AM
nismos14's Avatar
§è~® f®ÈÄk
Do you mean the shifter feels notchy? I don't know how the clutch would feel notchy. How many miles do you have on the clutch?
Old Jun 18, 2005 | 07:27 AM
96mAx2fast's Avatar
The clutch feels notchy. when i press it to the bottom i would say the last 10% of the process feels notchy and weird. The car shifts fine. I have 99k on the clutch.
Old Jun 18, 2005 | 08:32 PM
nismos14's Avatar
§è~® f®ÈÄk
I bet you just need to replace the clutch and T/O bearing.
Old Jun 18, 2005 | 10:22 PM
96mAx2fast's Avatar
That funny feeling just started about 3 days ago.. Im pretty sure i can go awhile with it. Its shifting fine!!
Old Jun 18, 2005 | 11:16 PM
96white's Avatar
Im doing it next weekend
Old Jun 19, 2005 | 03:40 PM
97BlackSEGold's Avatar
if your car shakes when you take off slowly, its your clutch. I'd replace it though, i had the same thing on my camaro with 90,000 on the clutch and i decided not to bother with it, it was alright until one day when without warning, my clutch disk actually broke
Old Jun 19, 2005 | 03:45 PM
MDeezy's Avatar
try adjusting the grab point see if that helps smoothen things out, if so I believe its getting worn out.
Old Jun 19, 2005 | 07:35 PM
goodbye15's
As long as you have the transmission off you might as well replace all the clutch components.
Old Jun 20, 2005 | 09:41 PM
96mAx2fast's Avatar
where is the grab point adjusted from?
Old Jun 21, 2005 | 09:36 AM
MDeezy's Avatar
check in the how-to's there is a description of how to adjust it,
but the jist of it is look behind the clutch pedal, you'll see the shaft that goes into the fire wall, closer to you there will be a bolt that you'll losen and then you can rotate the shaft clock wise (grab point closer to the floor) or counter clock wise (grab point away from the floor).
Old Jun 21, 2005 | 09:46 AM
DR-Max's Avatar
I believe adjusting the clutch pedal doesn't do anything except make the transmission go into gear a little easier. The clutch will still behave the same way. Replace it asap, prolonging it could result in more damaged parts. The flywheel could get damaged to the point of needing replacement. Those suckers aren't cheap.
I replaced my clutch 3 weeks ago and when I got the worn out clutch out, it was worn down to the rivets. It started gouching the flywheel, luckily I was able to still reuse it by resurfacing the flywheel.
Old Jun 21, 2005 | 09:51 AM
MDeezy's Avatar
Good advice.
But ajusting the grab point can help prolong the life of the clutch if needed. by no means will adjusting the point be a solution but more of a means to help determine the problem. I adjusted the grab point on my clutch when it was acting up it helped for a few weeks, but then the problem slowly returned. As previously advised get it check out. Flywheel on jerryromenissan about $250. . . ouch.
Old Jun 21, 2005 | 10:17 AM
DR-Max's Avatar
Pinnacle has it for $183. Those guys are my new OEM Nissan Parts source. Been buying a lot of stuff from them. Also, factor in your other parts that need replacing aside from the fw and clutch, you might as well replace the pressure plate/cover and bearings. It all adds up. A flywheel can ruin your allowance for the week though, I know it would have ruined mine.
I didn't mention that before I changed the clutch, I replaced the master and slave cylinders and hoses because of leaks in the system. After replacing them, my car wouldn't go into gears. So we adjusted the pedal and it fixed that. At that time, my clutch was already slipping but in 2 weeks time (since I replaced the master/slave cylinders) until I replaced the clutch, the slip got worse and worse. The adjustment did help in one way but killed the clutch faster. I couldn't pass anyone, nor accelerate normally. Everytime I press on the accelerator, the RPM would climb up quickly and gradually go down as the clutch tries to grab. I drove my car to my friend's tranny shop so we could work on it. The last block before I got there, the clutch was barely grabbing. It was on its last leg.
Good thing I didn't drive my car for a week before that.
Originally Posted by MDeezy
Good advice.
Old Jun 22, 2005 | 06:13 PM
96mAx2fast's Avatar
Do you need two people to adjust the grab point. i would like my grab point to be closer to the floor. right now its at about half way..
Old Jun 23, 2005 | 01:02 PM
MDeezy's Avatar
no just you and some tools.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
