rough idle and diming lights???
Old Jun 18, 2005 | 09:41 PM
blinelaxd27's Avatar
hey my car has a rough idle and i can see the window where the milage is dimming a little with every uneven rev if that makes sense. I am trying to figure out what is going on.. i cleaned the throttle body and that didn't seem to help... any other ideas?? i really want to get it figured out, especially b4 i put in nitrous and other stuff. Maybe its the sparkplugs or coil packs??? give me ur ideas thanx.
Old Jun 18, 2005 | 10:04 PM
JPMax's Avatar
What's next!?..
check the battery and alternator. autozone will test them for free.
Old Jun 19, 2005 | 01:46 PM
PARALLEX's Avatar
ground the big 3....
Old Jun 19, 2005 | 01:56 PM
Batxel's Avatar
blah
how low does the rpm go? check spark plugs & coil packs
also, go through the stickies there's a couple hundred different things that can cause a rough idle
Old Jun 19, 2005 | 03:36 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
well if your alternaor is bad, that will cause your car to not have enough voltage to supply the ignition coils to saturate them fully. that would cause your car to run rough.
captchaos
Mar 15, 2016 12:18 PM
fastcarny
Oct 6, 2015 10:42 AM
ballerchris510
Sep 10, 2015 09:35 PM
Maxima30
Sep 7, 2015 06:13 PM
