wierd control arm issue- i think
Old Jun 21, 2005 | 05:26 PM
cydrive's Avatar
Here's the thing, i got two new control arms put in a little while ago. Now I'm getting strange groaning/creaking noises from one side and I cant figure out what the heck it is. Its only on the passenger side and i here it if
a) i'm backing up and i have the wheel turned to the left and I'm about to stop and put it in 1st- this is when I get the creaking/ groaning
b) there's some vertical space between my driveway and the street, about and inch. Now, when I'm getting out, nose first and have to turn right, i get this dulled "bang" like i used to get with the worn balljoints
I can also feel the right side a bit more on the wheel when I go thru the rough roads around here. I dont know what to think; I jacked the car up to take a look at it and everything's pretty tight. I even tried to loosen those bolts and then tighten them.
Control arms/ sway bar links are new like a couple of weeks, struts were replaced a year and a half ago so I figure I have about 28k on them.
What's the deal with this?
Old Jun 22, 2005 | 04:26 AM
cydrive's Avatar
c'mon guys, anyone?
Old Jun 22, 2005 | 06:23 AM
Mishmosh's Avatar
If the control arms and FSB end links are new, more than likely, the problem is with the strut/spring assembly. Maybe worn strut bearing or mounts. If you have lowering springs, spring noises are not uncommon.
Old Jun 22, 2005 | 07:16 AM
NmexMAX's Avatar
dot dot dot ...
Old Jun 22, 2005 | 03:06 PM
cydrive's Avatar
hmmm, i'm not lowered at this time but given there's nothing else in the area....that could be it. I was actually planning on getting a set of H&R's with Illumina's mid-summer- this could actually give me an excuse to get them sooner since I have to disassemble them anyway..
tarun900
19
Dec 20, 2021 06:57 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
