P0440 Evap Emission Control system
Old Jun 24, 2005 | 10:57 AM
BIGHANK's Avatar
I'm running this trouble code and my car does not feel the same while driving. It drive's like i'm stuck in 3 gear. What should i check to replace? HELP ME OUT!
Old Jun 24, 2005 | 11:14 AM
KCMaxima98's Avatar
My suggestion is to take it to the stealership or a trusted mechanic. It could be your vent control valve. Evap problems are sort of hard to diagnose IMO and when i had my vent control valve replaced at the stealer it was only just over a hundred dollars to fix. No more CEL and no more worries. Although, it shouldn't affect the way the car is running, or at least it didn't on mine. Funny thing you mention this. My camry is in the shop for a CEL right now that is related to the EVAP system. First problem I have ever had with the toyota and it is a 99 with 95K on it now. I wish my maxima was half as reliable as that car lol.
Old Jun 24, 2005 | 11:48 AM
BIGHANK's Avatar
Thanks For The Reply. Is The Evap Hard To Locate And Replace. Im Not That Bad At Replacing Parts On My Max 97.
Old Jun 24, 2005 | 02:31 PM
KCMaxima98's Avatar
The vent control valve, which was my busted part, is located behind the driver's side rear wheel. But, I had like three codes. If something in the EVAP system isn't working properly, you can get multiple codes. I wasn't just going to start swapping parts. I do plugs/filters/fluid changes and thats pretty much it. The evap system is kind of complicated for me so I chose the stealership. Good luck.
homeofbacon
Sep 23, 2015 07:17 PM
DayHeyZeus
Sep 11, 2015 03:17 PM
220k+ A32
Sep 11, 2015 02:18 AM
carid
Sep 9, 2015 05:06 AM
dcam0326
Sep 7, 2015 07:26 AM
