Projector
Old Jun 24, 2005 | 01:51 PM
CKOTuHA's Avatar
Projector
If I have projectors already in my stock lens, can I still bake the lens to open them up? I have E46 bixenons with solenoid inside the lens, nothing would melt or get screwed up?
If so, what degrees and for how long?
Inside of my lens looks horrible, I have to clean it before I put them on the car.
Please answer as fast as you can.
Old Jun 24, 2005 | 02:02 PM
maximazation's Avatar
if your worried about melting parts inside your projectors, then use a heat gun, safer than baking your headlamps in the oven..IMO
Old Jun 24, 2005 | 02:23 PM
maximus_96's Avatar
set the over at 250 and it should be fine. the hid bulb burns hotter than that.
Old Jun 24, 2005 | 02:24 PM
CKOTuHA's Avatar
But what if a heat gun is not around? Oven is a bad idea?
Old Jun 24, 2005 | 02:27 PM
CKOTuHA's Avatar
For how long? Are you sure they won't melt?
After that just use a screw driver to seperate it?
Old Jun 24, 2005 | 02:34 PM
maximus_96's Avatar
what won't melt? the projectors? they're metal, you can't melt metal at 250*F.
Old Jun 24, 2005 | 02:44 PM
CKOTuHA's Avatar
The wires of the motor that moves the shield and the motor itself
Old Jun 24, 2005 | 03:13 PM
maximus_96's Avatar
the bi-xenon solenoid itself is not going to melt. the stock solenoid wires as i remember should be pretty thick. if your projector is using something thinner than the stock solenoid wires, then i would re-think it and invest in a heatgun. if they're stock then there should be no problem at 250,
Old Jun 26, 2005 | 11:13 PM
p00tan6's Avatar
I've done a retrofit on my max. It will be fine in the oven at 250 degrees for 10 minutes.
Old Jun 27, 2005 | 02:37 AM
alphaerror's Avatar
bake at 250 for 10 min. Remove and and serve immeadiately. Serves four.
Vistance
Sep 17, 2015 05:17 AM
umnitza
Sep 1, 2015 01:03 PM
see_fu
Jun 15, 2002 03:24 PM
