Strut Bar Help
Old Jun 29, 2005 | 07:50 AM
MaxxedOut624's Avatar
Strut Bar Help
I know this is probably really easy but I have never done it before...is there anything I should look out for when putting on the FSTB or is it as simple as unscrewing the 3 screws on each side of the engine bay and put the strut bar in. I tried that yesterday but the screws wouldnt even move so I sprayed the crap out of them with WD40. Any advice on this would help. Thanks.
Old Jun 29, 2005 | 07:59 AM
kormax97
I used a torque wrench and used 110% of my strength to loosen those 6 nuts.. it's hard but you gotta really put your power into it... oh and don't use wd40. I poured goo-gone on the nuts and let it sit for about a minute and got them loose pretty good. (goo-gone is not a lubricant.. it cleans the dirt)
make sure you read post #8 also @ http://forums.maxima.org/showthread....50&page=1&pp=8
Old Jun 29, 2005 | 08:26 AM
Bobo's Avatar
Don't over tighten the nuts once the FSTB is installed.
Old Jun 29, 2005 | 12:21 PM
86maxima96's Avatar
I Broke OT
i just ordered an OTTO bar. if it doesn't come with instructions, am i correct in remembering that 30 ft/lbs is a good torque measurement to tighten it to with a torque wrench?
Old Jun 29, 2005 | 02:53 PM
jackiss2888's Avatar
dont worry about the pressure. you need to take a normal socket/rachet and put the arm of the rachet through the circular hole of a wrench to provide more leverage. THIS WILL MAKE EVERYTHING MUCH MUCH MUCH EASIER. I promise you all this.
Pnjboyzz
Nov 16, 2015 12:27 PM
MaxLvr21
Oct 17, 2015 12:11 PM
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
