A/C Compressor squelling
Old Jun 29, 2005 | 03:55 PM
Bill73083's Avatar
Sometimes when I turn on my A/C or defroster I hear a squeeling noise. I believe that it is the A/C compressor. I know that eventually I will have to replace it, but I am wondering if there are any temporary fixes for this, such as greasing it up or tightening something or other.
Old Jun 29, 2005 | 03:59 PM
THT's Avatar
THT
Throbbing member
Take a look at your drive belts first. Check for cracks, too much deflection, and other signs of wear. I suggest this because when you engage the compressor, the drive belt is subjected to more stress and yours may be nearing the the time for replacement/adjustment.
Old Jun 29, 2005 | 04:31 PM
Bill73083's Avatar
I just replaced my drive belts about 2 weeks ago.
Old Jun 29, 2005 | 06:32 PM
Max Atlanta's Avatar
Check your deflection. It should be about 1/8 or so. I replaced my belts a few weeks ago and had to adjust the deflection about two days later. I didn't tighten the idler pulley bolt enough and it slipped just enough to make a slight squeal. It doesn't squeal at all now.
Old Jun 29, 2005 | 07:45 PM
nismology's Avatar
Once you install a new accessory belt you need to retension it after it has been broken in.
Old Jun 30, 2005 | 08:24 PM
Bill73083's Avatar
Now when I hear the noise there is a slight smell. Its very subtle and hard to describe, but its definatley there. Once again, this only happens once in a while, and seems to happen more on muggy/humid nights.
Old Jul 1, 2005 | 10:37 AM
1995WhiteMaxima's Avatar
It's definitely your belts. I have the same exact issue on those muggy and slightly muggy days and I know its my belts because my belt tensionor is busted (no bolt) and that would explain the slack on my belts. The AC compressor is burning the belts when you turn it on, so you better adjust the pulley asap. Hope my experience helped.
BkGreen97
Apr 2, 2016 05:47 AM
mclasser
Sep 24, 2015 11:57 PM
homewrecker
Sep 24, 2015 07:01 PM
pears
Sep 18, 2015 05:25 AM
