any suggestions on a clutch???
#41
Originally Posted by 96stillen_max
uncivilized is buying a $400 stage 1 clutch for an n/a maxima.
But why do you feel that way?
And I agree with fr33way, the clutch engagement is very manageable. I drive in NYC city frequently, and do a lot of stop and go around town, plus I'm an active-shifter *****, meaning I tend to upshift and revmatch-downshift through the whole range all the time, everytime.
I find the engagement and feel to be tighter and more predictable than stock, but you'll likely find that's the case anytime you replace a old-worn out part with a new one. Keep in mind, the heavy duty/stage 1 pressure plate is designed with street-ability in mind, so you won't have a sore left leg, unless you have pipe-cleaners for legs or something like that...But yes, it's tight, but not too tight as to require a high degree of attention all the time.
#42
Originally Posted by Feed
I totally understand that this is your opinion, and I respect that...
An OEM 5th gen setup, which costs only $200 (as opposed to the ACT $400) will last A LOT longer than a stage 1 clutch and will have more than enough grip you will ever need for your n/a max. In my mind I just dont see any reason for getting one unless you are boosted or have nitrous.
#44
I would think so. But you could always call up the Infinity dealer and ask if Nissan part numbers are for the same parts from Infinity. Its the same company so thats why I would htink they are, but you never know.
#45
Originally Posted by Chickan
really? See I don't really like mine, as its much lighter pedal than the stock clutch. is this the same in your case?
#46
I feel that way because the only reason I can see why someone would put a stage 1 clutch on an n/a max is so that they can chirp 3rd, I see no other reason why you would get one.
I think the 5th gen is a great setup and if I wanted a stock feel that is without question what I would get.
#51
Originally Posted by maximariceboi
hey guys..i have a bit more than 89k on my lakeshore blue max. will be needing a clutch soon...but i think it will last another 5k miles =] its the original clutch so yea...lots of mileage on it.
i been looking around for clutches and dont know what to choose from the few. i need something that can last long and performs very well. i was considering the following:
ACT stage 1
ACT stage 2 (might boost)
SPEC 2
JWT
Unorthodox racing ultra G ceramic (not sure which one)
thats about it..anyone have any of these??? and can tell me how they are? thanks!!!
ACT stage 1
SPEC 2
JWT
My original Clutch has 125k on it and still grabs like the day i bought it. That is with 45 passes at the track. You may wanna just get 5th gen clutch setup
#54
is it worth changing to an aftermarket flywheel?
#55
Originally Posted by THT
Depends on who you ask. My understanding of it is that while your engine can rev up faster, revs also fall faster, launching is harder, and basically, there's less room for error. Would I pay $300 for the privilege? Probably not.
DC_Juggernaut
09-28-2015 04:07 PM
Pied
09-26-2015 03:29 PM
