Symptoms of a bad brake master cyl?
Old Jul 2, 2005 | 05:10 PM
Nismo's Avatar
What are the symptoms of a brake master cyl going bad? What things can cause them to go bad?
Old Jul 2, 2005 | 05:16 PM
enomik-1's Avatar
When you start losing pressure in the clutch pedal or clutch pedal gets stuck
to the floor.. Ive had this problem... As for an automatic max I dont know of
any symptoms..
Old Jul 2, 2005 | 05:34 PM
njmodi's Avatar
Do I get a tax break?
any symptoms..
What does a clutch pedal have to do with the master brake cylinder?
Old Jul 2, 2005 | 05:56 PM
Sniper's Avatar
In some cars, the brake master cylinder holds the fluid for both the clutch and brake systems.
Sometimes, a spongy brake pedal can indicate a worn or leaky master cylinder. A pedal with lots of travel...all the way to the floor is also a sign there may be a problem.
Things that can make a master cylinder go bad...time, bad seals, pitted walls on the inside of the cylinder...bad dumb luck.
Old Jul 2, 2005 | 09:14 PM
Nismo's Avatar
Thanks guys. I guess the brake master cyl sounds like its the problem.
btw, on 4th gens, the clutch and the brakes have their own independant hydraulic systems.
Old Jul 2, 2005 | 11:09 PM
Deagle's Avatar
wants the ads to die
Mine just went bad so I had it replaced. As far as the symptoms go, it feels as it it doesn't have any fade on it any more. The more I depressed the pedal the more it decelerates.
Old Jul 3, 2005 | 01:09 AM
Nismo's Avatar
How much did that cost you?
t6378tp
Sep 29, 2018 04:27 PM
hozay99
Sep 19, 2015 10:20 PM
Bonka
Sep 14, 2015 11:18 PM
bbsitum
Sep 11, 2015 04:55 PM
