autometer Oil pressure sender
Old Jul 5, 2005 | 07:36 PM
MAXecutive's Avatar
Does anyone know where I can get the T fittings and adapter to connect an autometer oil pressure sender unit and still have the factory one working too?
Old Jul 6, 2005 | 08:34 AM
1MAX2NV's Avatar
T fitting from home depot....1/8"NPT all around. The adaptor will have to come from Autometer. I forgot which one I bought that worked. I think it was the Oil Pressure 1/8" NPT to 1/8" BSPT Product #:2269
http://www.autometer.com/cat_accesso...st.aspx?pid=11
Old Jul 6, 2005 | 08:36 AM
1MAX2NV's Avatar
off topic...Automemter finally made a radiator hose adaptor. I had to rig a HKS to work.
Old Jul 6, 2005 | 11:08 AM
MAXecutive's Avatar
so home depot are all 1/8 NPT? that will go into the block? Do i use the adapter that came with the gauge? the "2269" is for the T to the sender? Where does the stock sender attach to?
Old Jul 6, 2005 | 12:56 PM
ronin22357's Avatar
courtesynissan.com sells a nismo t adapter. thats what i used
Old Jul 6, 2005 | 02:08 PM
1MAX2NV's Avatar
Autometer 2269 is a male 1/8" NPT to male 1/8" BSPT. This adaptor will go into the block. The block I believe is a 1/8" BSPT thread. Now, the T fitting is all female 1/8" NPT. One hole is where the autometer sendor will go. The other hole is where the stock oil pressure sender will go. You will have to screw the stock oil pressure sender all the way into the T but it will work. Use teflon paste on all the fitting or use blue loctite.
Look at my pictures. I used a SS line to relocate all the fittings. I didn't like the idea they are so close to the axle.
http://public.fotki.com/1max2nv/1max...and/page2.html
Old Jul 6, 2005 | 02:12 PM
MAXRB8's Avatar
Me too! wish I knew about the home depot thing
http://www.courtesyparts.com/Merchan...Category_Code=
Old Jul 6, 2005 | 02:24 PM
MAXRB8's Avatar
WOW How do you find time to watch the road?
Old Aug 1, 2005 | 08:26 AM
ChinoX's Avatar
Bring it B*tch!
From: Queenz, nYc CarClub: NYCMAXIMAS.ORG Website: www.ChinoX.net
Now is this for the electric or mechanical oil pressure gauge?!
Old Aug 1, 2005 | 11:27 AM
SPiG's Avatar
SomePsychoGuy
Either. Mechanical normally stays in the engine bay since you don't really want to run oil lines into your cabin.
The Electrical should just have a sensor that screws into the 1/8" NPT or you would need another adapter.
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
