HID mounting areas
Old Jul 5, 2005 | 11:06 PM
TurTLe*'s Avatar
HID mounting areas
I'm looking to pick up one of the plug and play HID kits from the GB. Most likely a 5000k kit. Not sure from who yet. There are like 3 of them right now. But i was wondering where everyone mounted the box for the HID to. I'm trying to locate some nice mounting areas to put it.
Did everyone upgrade their wiring harness as well? Where did you guys get them?
Is it really 15 mins to set up the kit? And if you guys just used the stock headlight housings.
Old Jul 5, 2005 | 11:51 PM
maximazation's Avatar
when i had my HID kit, i mounted the ballast and igniter on the body near the washer fluid for the left side and the igniter and ballast near the battery on the right. make sure to leave the igniter and ballast on the left side as far as you can from the washer fluid unless your ballast and igniter are waterproof, like mine were.
Old Jul 6, 2005 | 04:23 AM
mansurxk's Avatar
get the 6000k kit..i have the 5000k...in fact wait for projectors instead. im not happy at all. 5000k looks like a yellowish white, more on the white side though.
Old Jul 6, 2005 | 04:58 AM
achebee4you's Avatar
diddo., do it the right way with a real retro for real light output, otherwise ur wasting ur moeny if the capsule blows difficult/ expensive to get a new one and def not a color match.
Old Jul 6, 2005 | 05:46 AM
meanbean's Avatar
I have my ballasts located under the headlights. IMHO, this is the best place since it is concealed and protected. Here is a pic to illustrate.
Old Jul 6, 2005 | 05:50 AM
queenambeach's Avatar
You can get the upgraded harness at xenondepot.com for about $50.
Best advice would be to go with a retro. Also if you still decide to buy a kit, it's
better to get a kit with the ballast and ignitor integrated into one.
Old Jul 6, 2005 | 06:01 AM
Dasyce's Avatar
Why would intergrated be better, i always heard the opposite.
Old Jul 6, 2005 | 08:56 AM
TurTLe*'s Avatar
did you do a retro?
Any have pictures of an HID kit on a maxima w/o a retro? I just wanted to see how it might look like and how the patterns come out.
If i put in an HID kit w/o doing a retro, i'm just asking to get pulled over aint i ?
Old Jul 6, 2005 | 09:27 AM
happyricefob's Avatar
V^___^V
i have the 6k HID kit, it's plug and play on 9004. the beam pattern with 1995 headlight is horrible, but the light output is a lot brighter than stock halogen and gaybay xenon hyperwhite bulbs.
that's exactly where i "mounted" my HID kit. (more like ghetto zip-tie work)
My 6k HID kit vs. my friend's new G35 coupe.
Old Jul 6, 2005 | 10:00 AM
maximus_96's Avatar
i hope you reconsider about the HID Kit, read this link here, http://www.hidplanet.com/forums/viewtopic.php?t=3505
the proper way to do HID is to retrofit projectors. a few here has already done it. i'm almost done with mine. i got the kit from MAXIMABEST from the GB at first. the beam pattern is horrible because the 9004 reflectors suck. the worst part is that one day, a ballast just died for no reason. good thing i got AMEX to refund my entire purchase. I got the OEM ballasts, projectors and bulbs for about $350 on ebay which is not much more than those sh!tty kits from the GB.
Old Jul 6, 2005 | 10:35 AM
cefiro8701's Avatar
IMO...they look like they're missing something(other than the sides)...i think there shouldve been one more projector in each housing cause seriously, that looks like its missing something.
Old Jul 6, 2005 | 10:40 AM
maximus_96's Avatar
there's no way to fit 2 projectors in there given how wide the TSX projectors are, plus i think that would look funny.
Old Jul 6, 2005 | 07:47 PM
TurTLe*'s Avatar
does anyone here sell pre-done retro's?
Old Jul 6, 2005 | 07:50 PM
Mine came with some double sided tape that later on was a b!tch to take off.
Old Jul 6, 2005 | 09:42 PM
maximus_96's Avatar
no but you can pay to have somebody do the retro for you if you're not the handy type.
Old Jul 7, 2005 | 06:01 PM
bklynzsleepy's Avatar
i have 1 that is done already. the ONLY problem is that it's LOW BEAM only. there is no high beam to it. i used E39 low beam projectors.
Old Jul 7, 2005 | 07:18 PM
Nick7455's Avatar
I was worried that it somehow might work lose as I just had it sitting like in the pic above and then put back in the headlight but I drove over 5000 miles cross country this summer without a single prob....IMO this is easy and VERY safe for keeping it clean and dry and gaurded.
Old Jul 7, 2005 | 08:47 PM
TurTLe*'s Avatar
aren't most retro's low beam only?
Old Jul 8, 2005 | 08:29 AM
meanbean's Avatar
The choice of single or bi-xenon projector retro is all relative to the headlight you are modifying and the owner's preference. What I mean is that if the headlight you are modifying has separate hi/low bulbs, aka dual reflector housing, then people will tend to use single xenon replacements since the high beam reflector should remain after the retro. For dual filament bulbs used in a single reflector housing, the people will tend to go with a bi-xenon projector so that the function of the low/high beam will remain the same. People that decide on single xenon projectors to replace a single low/high reflector housing do so usually for several reasons. 1) Single xenon projectors can have a sharper cutoff than bi-xenon projectors. 2) Single xenon projectors can have a wider beam pattern than bi-xenon projectors. 3) Single xenon projectors can be smaller than bi-xenon projectors. 4) Their state inspection laws do no require their vehicle to have high beams. 5) All bi-xenon projectors available are too large to fit inside their headlight. If you are thinking about performing a retro into your headlight then consider what I have stated to help make your decision.
Old Jul 8, 2005 | 10:14 AM
eckohb's Avatar
btw, its not impossible to retro two projectors into one housing. ask homer mac, he did it.
Old Jul 8, 2005 | 12:06 PM
maximus_96's Avatar
dual HID projectors will be overkill. true that there will be much more forground lighting, but given the sharp cutoff of HID projectors, the intense contrast of the cutoff will be very stressful to your eyes. but if you're doing dual projectors purely for looks, then go with whatever that floats your boat.
Unclejunebug
Apr 2, 2016 05:42 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
sliptap
Sep 30, 2015 05:57 AM
