Hows Tokico HP Strut/Spring Kit performs?
Old Jul 7, 2005 | 07:55 AM
ruben's Avatar
Hey guys,
Anybody know how Tokico strut/spring kit performs? Its pretty cheap on ebay (about $300). I'm looking for a small drop with little sacrifies to ride quality. I read somewhere that HPs tend to leak out on stiff springs. I assume that the springs in the kit are not that stiff. Am I right? Is it decent or I should really go for illuminas?
Thanks!
Old Jul 7, 2005 | 08:13 AM
mzmtg's Avatar
Minister of Silly Walks
I was never impressed with the HP struts. I ran them for about 75k miles with 3 different types of springs. Save a little more dough and get the Illuminas.
Old Jul 7, 2005 | 08:36 AM
d00df00d's Avatar
Old enuf to pick his own gears
The HP struts are just OEM replacements, so the're not very good. The springs are the same springs that come with the Illumina kit, though, and those are supposedly very good. The problem is that the struts will barely be able to control the springs, so your ride will be significantly harder and bouncier.
If you're looking for a discrete drop with minimal sacrifice in ride quality, you need Tein H-Techs (1" drop -- less drop than ANY other spring) with Tokico Illuminas or Koni Yellows. They'll be pricier, but anything else will give you a much bigger drop and a much worse ride.
Then, once you've got those, plan on adding chassis stiffening (Stillen FSTB, BlehmCo stage 2 lower tie bar, Warpspeed subframe connectors) and start looking into lightweight rims and tires. I'd recommend 15" Kosei K-1 Racing or Rota Slipstream wheels with 215/55/15 Falken Ziex ZE-512 tires.
That'd be one hella comfy Max -- comfier than any stock GLE -- and handling-wise it'd easily hang with the Tokico HP kit.
Old Jul 7, 2005 | 10:14 AM
brooklynK3Y
Why would the Tein H Tech be less of a drop than any other spring? The Front is 1.6" and the Back is 1.2".. But thats for when or if you got a System in the back, if your system is good enough, it would even out the height of the max and the back and front would be about the same inch.. I Got Tein H Tech, and Its a better drop then any of my friends Max. Looks nice & Low in the front, only thing is that i got to put the system in the back to kill the 3 finger gap & then finish off the body kit.. And the car will look low and nice
Old Jul 7, 2005 | 10:54 AM
d00df00d's Avatar
Oops. Just checked Tein's site, and you're right. I had been going by what I had seen on other websites, which listed an approximately 1" drop. I stand corrected.
Still, the H-Techs have a reputation for being tied with H&R as by far the comfiest spring for the Max, so my recommendation stands.
Sorry about the error.
Old Jul 7, 2005 | 11:52 AM
brooklynK3Y
we all make mistakes
JRod28
Dec 29, 2023 09:56 PM
Matt93SE
May 24, 2019 02:58 PM
homeyclaus
Sep 3, 2015 06:15 PM
95Maxi
35
Sep 2, 2015 10:37 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
