recommend brakes
recommend brakes
Im running at about 76040miles and i dont believe that my brake rotors have been changed since the day they left the factory...what kind of rotors would u guys recommend?OEM or some other BETTER aftermarket set??sorry i looked through the faqs and saw nothing about brakes. also if you guys could just point me into the right direction(previous posts) that'll be very helpful.
for brakes if you arent running much more than stock power then, OEM Pads, good fluids, and SS lines should firm up brakes and feel like new.
Rotors you got me, I'm interested in responces because I know mine havent been changed or service for as long as I've known the car. You can have your rotors "turned" where they cut off a thin layer of the rotor to make it balanced.
I have Powerslot rotors and Hawk HPS pads up front. I am happy with their performance. I get a good amount of brake dust, but I don't mind it.
Some good reading:
http://maxmods.dyndns.org/index.php?MaximaBrakePads
http://maxmods.dyndns.org/index.php?MaximaBrakeRotors
http://maxmods.dyndns.org/index.php?MaximaBrakeLines
Some good reading:
Originally Posted by FishyMan
yes. it will according to the DIY.
anyboyd used generic brand rotors?
I use Performance friction Z carbon metallic pads on my 300ZX bbk, they are quiet, no fade, and minimal dusting, you can get the pads for $40 online for the stock Maxima brakes ( I have a new set that I didn't use as I converted to 300ZX bbk) Look at Raceconcepts or Stopchek on ebay for good deals on "maxima rotors" search.
Got the pads from these guys:
http://www.nationalfleetparts.com/pf...ima&year=1996&
umm...see the thing is i need stuff that will handle me going downhill at somewhat high speeds...i go up in the california hills more often than not so yeah...i kinda need strong stuff here....how much do brembo blanks cost???
i use Raybestos QS with stock OEM rotors and that combo sucks because they create so much dust that it makes my 18s look like a totally different color.
It all depends on how much you want to spend and how hard you drive. If you spend the $ and get slotted they will stop much better but the slots shave your pads each time you brake thats why there is more brake dust. Regular rotors wont stop as effectivly but your pads will last longer. I went with brembo replacemet rotors and PBR semi metalic pads i love em
Apr 16, 2020 05:15 AM
MaxLvr21
Oct 17, 2015 12:11 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
