Help, car wont start again!! (kinda long)
Old Jul 9, 2005 | 01:19 PM
sean33's Avatar
So it finally got to the point where my car won't start again, and I'm trying to get an actual answer instead of taking it to the mechanic and have them scratching their heads for 5 days again.
Originally my car didn't start very well then it slowly didnt start at all. Pushed in the clutch and turned the key and nothing. No battery problems nothing. It seemed to get worse and worse as the summer when on and the car was hot. I took it to a mechanic and they had it for a whole week and all they could do was deactivate the alarm system and do some sort of over ride to get it to start. So when I got the car back it started everytime but it started reallly rough and died a lot after the engine turned over. This was all new, my car started perfectly before. And now my alarm was broken.
So a year later and summer is kicking in and the same thing is happening. It slowly is getting harder and harder to start and today I couldn't even start it. Help, I have no idea whats causing the problem and its really frustrating.
Here the symptoms:
-No sound when I turn the key
-Occasionally will start for no reason
-Mechanic thought the alarm system was the fault so tried to fix it, second mechanic said the same thing to me when I was chatting with him.
I know I saw other people having similar problems wondering if anyone actually knows the electrical problem with my car.
Old Jul 9, 2005 | 01:21 PM
sean33's Avatar
One more thing, I have water damage in the trunk from a leaking trunk. It could be effecting the alarm system as well.
Old Jul 9, 2005 | 04:43 PM
njmaxseltd's Avatar
It's either the starter or the ignition switch.
More likely the ignition switch acting up as the interriior of your car heats up in the summer months.
Old Jul 9, 2005 | 05:03 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
ignition switch. very easy to replace.
our NVIS(vehical immobilizer) uses a single wire to connect to the ECM, see if they disconnected it.
Old Jul 9, 2005 | 05:09 PM
wannaboostbad's Avatar
Already checked the Clutch ON/Off switch? Maybe Ohm it out? try to check the wiring for the alarm like, maybe it wont de-activate the alarm and allow it to start.
Old Jul 9, 2005 | 08:53 PM
GarciaMaxima's Avatar
my car just wonuldn't start one day. No kind of noise when I turned the key. I remembered that I was getting a winding noies form the started, so that's the first thing I replaced and BINGO it starte right up!
Good luck
Old Jul 10, 2005 | 08:50 AM
VeN0m's Avatar
It's the ignition switch. The stock one has a short that develops due to a bad solder. It is stealing the juice from the coil packs. 20$ and 20 mins of your time. Good luck.
Old Jul 29, 2005 | 08:24 AM
sean33's Avatar
Hey guys I replaced the old ignition switch with a new one yesterday my car fired up clean and on the first turn of the key three times in a row and it started great this morning. This compared to the previous day where I could hardly start the car and started getting a blister on my finger from turning the key so many times in frustration.
THANKS GUYS!!!
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
JRod28
Feb 4, 2016 11:07 AM
criminalslang810
Aug 16, 2015 08:12 AM
Maxboy23
Aug 11, 2015 11:59 AM
