ECU differences b/w CA and Fed spec
Old 07-10-2005, 01:39 PM
THT
Throbbing member
THT's Avatar
I have a 96 that I'm converting a 5spd. The car was originally purchased in California and I checked the information plate to verify it is a CA spec model. I want to know if I can run a Fed spec ECU without a CEL coming up.
THT is offline
Old 07-10-2005, 02:03 PM
Kevlo for President
Kevlo911's Avatar
You should be able to, those ECU's are not very emmision(EGR/EVAP) sensitive.
Kevlo911 is offline
Old 07-10-2005, 02:06 PM
THT
Throbbing member
THT's Avatar
Not to contradict you Kevlo, but an org member is having CEL issues running an ECU from a CA spec 95 in his fed spec 95...something about EVAP in CA spec being electronic vs. mechanical in a fed spec.
THT is offline
Old 07-10-2005, 02:23 PM
Kevlo for President
Kevlo911's Avatar
Power keeps turning off because of that Hurricane. This is my third time typing this
Kevlo911 is offline
Old 07-10-2005, 02:24 PM
Kevlo for President
Kevlo911's Avatar
I know the early 95 had a different EVAPsystem(Haynes Manual). I do not know if it is a FED/CALI thing. I am pretty sure that was a production date thing.
Kevlo911 is offline
Old 07-10-2005, 02:28 PM
Kevlo for President
Kevlo911's Avatar
96-98 Have same EVAP and EGR system
Kevlo911 is offline
Old 07-10-2005, 02:35 PM
THT
Throbbing member
THT's Avatar
Thanks Kevlo.
THT is offline
Old 07-10-2005, 05:09 PM
Armed and Dangerous
i30ds's Avatar
I thought CA spec only existed in 99+?
i30ds is offline
Old 07-10-2005, 05:32 PM
THT
Throbbing member
THT's Avatar
No. My car is definitely a CA spec.
THT is offline
Old 07-10-2005, 06:21 PM
Kevlo for President
Kevlo911's Avatar
All 4th gens had Cali spec, but only 99's had MAJOR differences.
Kevlo911 is offline
Old 07-10-2005, 07:07 PM
I'm nutty for Nissans
JSutter's Avatar
a 95 fed spec has a mecanical evap (all under the hood), no boost sensor, and the egr runs off the same solenoid as the evap. a lot less complicated to do the exact same crap. all 96-98's are the same.
JSutter is offline
THT
Throbbing member
THT's Avatar
So all 96-98 5spd ECUs, regardless of CA or Fed spec, are the same?
THT is offline
Old 07-11-2005, 04:50 PM
THT
Throbbing member
THT's Avatar
If all 96-98 5spd ECUs are the same, why can't JWT/TS upgrade 97 and 98 ECUs?
THT is offline
Old 07-11-2005, 07:24 PM
Kevlo for President
Kevlo911's Avatar
ECU's are not the same. I said the 96-98 have same EGR and EVAP.
In 97 Nissan changed the maker of the ECU, that is why they cannot be upgraded.
Kevlo911 is offline
Old 07-11-2005, 07:29 PM
THT
Throbbing member
THT's Avatar
Ahh, gotcha.
THT is offline
Old 07-12-2005, 07:03 AM
Armed and Dangerous
i30ds's Avatar
Yeah thats what I thought... Mainly the extra pre cat and O2. So, is it safe to say that there is no difference between say a 97 fed and CA spec?
i30ds is offline
Old 07-12-2005, 07:07 AM
Kevlo for President
Kevlo911's Avatar
I dout we could find any, if any differences, it would be weaker ECU tuning.
Kevlo911 is offline
Old 07-12-2005, 07:14 AM
Armed and Dangerous
i30ds's Avatar
What exactly do you mean by weaker ECU tuning?
i30ds is offline
Old 07-12-2005, 07:36 AM
Kevlo for President
Kevlo911's Avatar
Cali has stricker emmisions and what not, it also has lower grade octane.
Kevlo911 is offline
Old 07-12-2005, 07:40 AM
MaxxAddict's Avatar
Don't mean to hijack this thread, but if I were to try to put a JWT 96 5speed ECU into a 98 5speed maxima (both fed spec), what would need to be done? What additional modifications would be necessary to not get a CEL? Is there a link someone can redirect me to? Thanks!
MaxxAddict is offline
Old 07-12-2005, 01:03 PM
Armed and Dangerous
i30ds's Avatar
http://forums.maxima.org/showthread.php?t=350138
i30ds is offline
Old 07-12-2005, 01:09 PM
MaxxAddict's Avatar
Thanks. but I think i'm more confused now!
Intimidating task for a novice like myself.....
Old 07-12-2005, 01:24 PM
Armed and Dangerous
i30ds's Avatar
YOu could just leave the codes alone. Depending on where you live it might not even matter that the CEL is on. Here in CO if it is on, the go ahead and run the vehicle anyways and if you pass, then you pass. And these two codes will not effect emissions performance. If worse comes to worse, you could always pull the gauge cluster and reomve the bulb every 2 years.
i30ds is offline
Old 07-12-2005, 01:31 PM
MaxxAddict's Avatar
hmmm, are ECUs interchangable?
What I'm asking is a hypothetical question. Suppose I obtain a used 96 ECU and send it to JWT to be modified and I then install it. Now what if later on I want to put my previous 98 stock ECU back in. Could I theoretically plug that puppy back in w/o any probs and the CELs? (suppose I wanted to sell the car and return it to stock settings.)
Old 07-12-2005, 01:42 PM
Armed and Dangerous
i30ds's Avatar
That should work.
i30ds is offline
Old 07-12-2005, 01:55 PM
MaxxAddict's Avatar
That should work.
Interesting indeed.
One more question: my car is Cali-spec according to the code on the little silver badge on the inner portion of the hood area (followed the instructions on the stickies, where the 12th letter is a "V"). But apparently when I installed my y-pipe I found out that my car is Fed Spec. Would this discrepancy be a factor when searching for replacement 1996 5speed ECU?
Thanks very much. You've been very helpful.
Old 07-12-2005, 02:10 PM
Kevlo for President
Kevlo911's Avatar
Only 99cali have differ exhaust, 95-98 Fed/Cali have same exhaust. You 98 is Cali
Kevlo911 is offline
Old 07-12-2005, 02:13 PM
MaxxAddict's Avatar
so i would need to find a cali 95 or 96 ECU from the junkyard? or would it not matter either way?
Old 07-12-2005, 02:16 PM
Kevlo for President
Kevlo911's Avatar
Like said above, it might be better to get a 96 since it would have similar EGR/EVAP equipment
Kevlo911 is offline
Old 07-12-2005, 02:20 PM
MaxxAddict's Avatar
ok. thanks kevlo911. you've been a great help!
96 cali 5speed ECU it is!
Old 07-12-2005, 03:10 PM
Armed and Dangerous
i30ds's Avatar
I think he is just referring to getting either cali or fed spec ecu... Just as long it is a 96.
i30ds is offline
Old 07-12-2005, 03:17 PM
MaxxAddict's Avatar
works out even better! thanks.
now to decide whether it's even worth the $600 to send it in.......
Old 07-12-2005, 03:20 PM
Kevlo for President
Kevlo911's Avatar
Kevlo911 is offline
Old 07-12-2005, 03:32 PM
Armed and Dangerous
i30ds's Avatar
Oh I think it is... I got a 96 5spd ecu sitting up in my room right now that is ripe for modding! I plan on sending it in as soon as I can stock pile up some cash.
i30ds is offline
Old 07-12-2005, 03:39 PM
MaxxAddict's Avatar
you get it online (carparts.com) or at a junkyard?
Old 07-12-2005, 03:47 PM
mansurxk's Avatar
im the person THT was referring to regarding the fed spec vs cali spec...my car is a 95 5speed fed spec, mistakingly purchased a TS cali spec 95 5speed ECU. its throwing codes for the EVAP and a fuel temperature sensor. since the evap is mechanical on my 95, the cali spec ECU is throwing a code because its looking for a different part (electrical EVAP). but the car runs the same as before. i hate CELs, i wish i had the proper ECU
mansurxk is offline
Old 07-12-2005, 03:52 PM
Armed and Dangerous
i30ds's Avatar
No I got it for $90 from Zack342's 96 I30t 5spd that he bought for a parts car.
i30ds is offline
Old 07-12-2005, 03:55 PM
MaxxAddict's Avatar
oh sweet deal.
Old 07-13-2005, 12:47 PM
Armed and Dangerous
i30ds's Avatar
oh sweet deal.
Thats what I thought! Some of the other guys were like
i30ds is offline
Old 07-13-2005, 03:02 PM
Zack342's Avatar
Then 3 weeks later i was in a frenzy to find a 1996 5speed ECU to send to JWT.
Zack342 is offline
Quick Reply: ECU differences b/w CA and Fed spec
