Still Reading Ks Code!!!!!
Old Jul 10, 2005 | 04:14 PM
Blaxima911's Avatar
Hey everyone, I changed out my knock sensor over a week ago and the code is still on. I've been driving it everyday and I need to get it inspected. Is there something I'm not doing right? All I did was pull the old one out and put the new one in it's place. Should I disconnect the battery or anything of that sort? Thanks for the help.
Old Jul 10, 2005 | 04:26 PM
MrDicks95SE's Avatar
Offset Is Everything.
reset the ECU
Old Jul 10, 2005 | 05:55 PM
Blaxima911's Avatar
Cool, thanks.
Old Jul 12, 2005 | 04:20 PM
Blaxima911's Avatar
Ok, I'm still doing something wrong here. Is resetting the ECU the same thing as resetting the check engine light? I've tried to reset the code with a screw driver a hundred times and when I check the code keeps coming up. Does anyone have any suggestions? I really need to get the car inspected. Thanks for the help.
Old Jul 12, 2005 | 04:39 PM
THT's Avatar
THT
Throbbing member
Yes. Here's the idiotproof method: disconnect the battery for five minutes.
Old Jul 12, 2005 | 05:37 PM
njmodi's Avatar
Do I get a tax break?
You might not be resetting the ECU correctly - and Yes it is the same as resetting the CEL.
Double check that you actually reconnected the sub-harness (if you ever disconnected it). You should also clean the two ground bolts on the front of the plenum (10mm I believe). With the sub-harness disconnected, you should be able to measure 550kohms on your new sensor (between one of the pins in the harness and an engine ground).
Old Jul 13, 2005 | 05:45 AM
knight71's Avatar
I had the same problem..retourqe KS and reset ecu again..it should go away.
Old Jul 13, 2005 | 06:26 AM
1995WhiteMaxima's Avatar
You can always get a friends OBDII autoscanner and erase the codes very easily.
sctludwig
Sep 1, 2022 01:32 PM
220k+ A32
18
Sep 22, 2015 11:39 AM
jchronis2552
Sep 21, 2015 05:52 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Steven Orozco
Sep 12, 2015 10:41 PM
