No more 4 x 4... finally...
Old Jul 16, 2005 | 07:23 AM
  #41
zad1
ya can you get a close up of the mirror
Old Jul 16, 2005 | 08:56 PM
  #42
elusive_max's Avatar
i'll take close up pic tomorrow been busy...
Old Jul 16, 2005 | 09:14 PM
  #43
sunten1
How much do the rims weight?
Old Jul 16, 2005 | 09:46 PM
  #44
superblack99's Avatar
not to ***** this thread but quick question...
how low should i go with my stock alloy wheels
Old Jul 16, 2005 | 11:37 PM
  #45
Brudaddy's Avatar
Looks really good man.
Props.
Old Jul 17, 2005 | 08:35 AM
  #46
hollaatchaboi's Avatar
so these would work?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7986666613
Old Jul 17, 2005 | 09:42 AM
  #47
MDeezy's Avatar
Originally Posted by DR-Max
Actually you are somewhat misinformed. According to Maxmod, Tokico Blues are an OEM replacement, just like the KYB GR2. Although the GR2 is somewhat better because its pretty much just like the AGX only non-adjustable and fixed at 2/4 (AGX setting). They should not be paired with stiff springs as they will blow out much sooner. The S-tech's spring rate is 201lbs front/280lbs rear. OEM is around 120lbs front/200 lbs rear. That's a big difference! Those Tokico Blues won't last you as long, you could have just slapped on a set of OEM's and save yourself some money instead because the end result is the same...blown struts. You should have gone with Tokico springs, H&R, or even H-techs at the very most. You should have done your research first instead of just asking everyone else, yes people's opinions do count up to a certain extent. Nothing beats doing your own homework. As for looks......the drop looks nice.
Amen. It looks great, but you'll look even worse when you have to dish out about $300-$400 for a new set of struts. Drop looks good, just worried about them blowing on you when you go over a hard bump one day with a car full of people.
Old Jul 18, 2005 | 05:28 PM
  #48
Originally Posted by hollaatchaboi
those are the one i got... they should fit find wit some extra moding to the mirror... wiring was easy
tseng1023
21
Oct 12, 2013 06:21 PM
Dooley
Aug 7, 2005 12:35 AM
maxed up
Mar 5, 2003 09:35 AM
Chris91SE
Nov 26, 2002 01:52 PM
areX
Oct 12, 2001 04:05 AM
