Still hesitating
Old Jul 13, 2005 | 11:59 PM
InsneDrmr's Avatar
Still hesitating
I changed out my PCV valve...it was needed...bad. It didnt make much of a differance in the feel of the car and how it performs. The car still hesitates a little bit in the lower RPM ranges...any idea?
New MAF - done
New KS - done
New Spark plugs - done
New PCV valve - done
New Fuel Filter - done
New Vacuum hoses - done
No codes being thrown, with the exception of the EVAP line code. Ill change that hose eventually.
I have heard of this problem happening on a few maximas, and it does need to be solved. Any more ideas?
Old Jul 14, 2005 | 08:47 AM
MDeezy's Avatar
check coil packs with multimeter.
Old Jul 14, 2005 | 09:19 AM
Chickan's Avatar
clean throttle body? Check TPS?
Old Jul 14, 2005 | 10:10 AM
InsneDrmr's Avatar
Checked coil packs, and they are all fine. Throttle body I havent cleaned yet, but I also havent had the time...I will try that as soon as I can. TPS is what?
Old Jul 14, 2005 | 10:17 AM
njmodi's Avatar
Do I get a tax break?
TPS = throttle position sensor.
The coil packs typically fail under load - so this might be your problem.
Definitely give the TB and IACV (idle air control valve) a good cleaning first.
JoshG
51
Sep 21, 2015 10:41 PM
jchronis2552
Sep 21, 2015 05:52 AM
trungg86
Sep 4, 2015 04:58 AM
conansriver
Sep 3, 2015 06:38 AM
