Signal light problem.
Old Jul 15, 2005 | 05:42 AM
knight71's Avatar
I bought some leds for my front turn signals, last night I put the led bulb in a the left front side only and it didn't work..first I assumed it was a faulty bulb. So I replaced it with the original bulb..nope...still didn't work..tried with both bulbs again..still dosn't work....Any ideas what could be the problem.
Old Jul 15, 2005 | 05:46 AM
kormax97
Was it working before you stuck a LED replacement in there?
Old Jul 15, 2005 | 06:01 AM
knight71's Avatar
yes it was
Old Jul 15, 2005 | 06:23 AM
kormax97
You might want to check the fuse or you might have just had a sh!tty luck and blown both of them at the same time. Try using your original right side bulb and see if it works on the left side. If it doesn't work again, put that bulb back in the right side and see if it works. If it does than it's either fuse or harness.
Old Jul 15, 2005 | 06:28 AM
knight71's Avatar
Thanks. I'll try that!
minsbang
Sep 11, 2015 08:48 PM
markevans999
Sep 10, 2015 04:29 PM
slowlifer
Sep 8, 2015 05:53 AM
Maxima30
Sep 7, 2015 06:13 PM
