Dark green/blackish "grease" on rim
Old Jul 17, 2005 | 04:12 PM
THT's Avatar
THT
Throbbing member
I was washing my car today and while cleaning my rims, I found a dark green, almost black substance that had the consistency of grease, covering the inside of the rim. This was the front, driver-side rim. It had also gotten onto the strut. What is it and what do I need to fix?
Old Jul 17, 2005 | 04:13 PM
njmaxseltd's Avatar
The CV boot broke open.
Act quick and replace the boot before the joint gets contaminated or else you'll wind up replacing the whole joint and or axle.
Old Jul 17, 2005 | 04:15 PM
THT's Avatar
THT
Throbbing member
I'm replacing the axle next weekend when I do the 5spd swap. Think it'll be okay for another 100 miles or so?
Old Jul 17, 2005 | 05:00 PM
njmodi's Avatar
Do I get a tax break?
THT - should be no problems (other than the mess) driving around for another 100miles (don't quote me on that ). Since you noticed the grease, the crack is likely recent.
Old Jul 17, 2005 | 05:14 PM
THT's Avatar
THT
Throbbing member
It wasn't there last weekend when washed my car so it had to have happened in the last seven days. I'm not too worried but I need to ask Mike what else I should buy.
Old Jul 17, 2005 | 05:16 PM
smokeyone's Avatar
Same thing happened to me, saw grease on friday. I'm planning on buying the whole half shaft and replacing it all next weekend.
njmodi's Avatar
You already have the axles for your new tranny right? As long as you have the axle seals you don't need anything else (as far as I know).
Old Jul 17, 2005 | 09:42 PM
Magikone69's Avatar
what could it be if you find alot of grease on top of the oil filter. i had my axles replaced already and the filter was instaled after the axle change. it was alot of grease too, like 2 fingers full of it. im lookin around and i have no visable leaks.
Old Jul 17, 2005 | 10:37 PM
Brudaddy's Avatar
Just make sure that your car is not making a clicking/popping noise when turning.
That means the CV joint is already bad, and could totally fail at any point. You don't really want this to happen when you are driving.
Old Jul 17, 2005 | 10:41 PM
DR-Max's Avatar
THT, you should be ok. When this happened to my truck (due to excessive front-end lift - IFS), I busted the boots. I drove it for several hundreds of miles before getting them replaced and have had no issues from that. Just avoid wet, muddy, and unpaved roads as the debri can get kicked up into the cv joints.
Old Jul 17, 2005 | 10:58 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
You will be fine for another 100 miles. I drove around with a torn CV boot for well over 2 months before the joint finally started clicking.
Old Jul 18, 2005 | 06:06 AM
maxgtr2000's Avatar
KH3 by popular demand
With all the axle/cv threads it looks like its just that time on the org. Funny how all of a sudden everybody is having this, I had to replace a axle/boot 3 weeks ago.
Old Jul 18, 2005 | 08:03 AM
BigLou93SE's Avatar
I'm in the same boat too.. My driverside axle boot/cv boot is cracked and leaking grease. I think I've let it go so long that I'll probably just spring for the $60 raxle axle when I get around to changing it.
Old Jul 18, 2005 | 11:10 PM
1996gle's Avatar
i think my axle need to be changed... whenever i turn it makes clicking noise yet i dont see any grease or anything like that.... how hard is it to change this ?? does the whole axle come iwth the boot and everything??
Old Jul 18, 2005 | 11:28 PM
eckohb's Avatar
WTF?!?!?!?! Not to go OT, but BRUDADDY EXISTS?!?!?! Where have you been?!?!
litch
123
Jan 4, 2024 07:01 PM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
0m3nc0w
Sep 11, 2015 05:21 PM
