For those who has a stick..
Old Jul 18, 2005 | 07:41 PM
MaxHijau's Avatar
When you shift gear, do you fully depress the clutch all the way to the floor? My told buddy told me it's not necessary to step all way to the floor. As long as I step the clutch to the point where I can shift, that will do it. Any thoughts? and why?
Old Jul 18, 2005 | 07:44 PM
MadaF's Avatar
just don't shift before you reach that point...
Old Jul 18, 2005 | 07:45 PM
THT's Avatar
THT
Throbbing member
I would depress the clutch past the engagement point before shifting to ensure you don't prematurely shift (e.g. while the engine is still transferring power). What's another two inchs?
Old Jul 18, 2005 | 07:47 PM
madnut's Avatar
There is a certain spot where the clutch grips every car is different, for ex on my stanza it would catch only when the pedal is almost fully depressed so i would need to press it in just a lil bit in order to shift. If you know the spot then u just need to press the peddle to a lil beyond that point.
Old Jul 18, 2005 | 08:05 PM
MaxHijau's Avatar
thanks for the input. i know if i shift after the clutch engagement point it should be ok. what i was thinking that it might lengthen the life of the clutch if i dont have to depress all the way to the floor.
Old Jul 18, 2005 | 08:13 PM
madnut's Avatar
Naa thats not what kills the clutch, that only will lenghten the life of the return piston
Old Jul 18, 2005 | 09:10 PM
DAVE Sz's Avatar
Hooooooonda.....
You should stop thinking from now on and read some books. How would this prolong the life of a clutch? When it's pressed in all the way the clutch is as far away from anything it can contact as it can. When it's out just past the disengagement point there is a chance it might still be slightly rubbing.
Old Jul 18, 2005 | 09:36 PM
Brudaddy's Avatar
push the clutch all the way in.
It is not good to do otherwise, even if it will shift technically.
Old Jul 19, 2005 | 12:21 AM
shmad's Avatar
do whatever floats ur boat. u can shift either way. like dave said, if u dont press enough, clutch plate might still be rubbing. u might possibly grind when trying to put into the next gear. just find that sweet spot. every girl...car has one
Old Jul 19, 2005 | 06:30 AM
MAXRB8's Avatar
Get an automatic........ if you're that lazy!
Old Jul 19, 2005 | 08:38 AM
MaximaSE96's Avatar
Maxima Owner
greatest quote evar
Old Jul 19, 2005 | 08:41 AM
mendon99's Avatar
tastey wheat
hahahaha
10char
Old Jul 19, 2005 | 09:08 AM
kingrukus's Avatar
no more maxima...
Old Jul 19, 2005 | 09:22 AM
Maximus_95's Avatar
Push it all the way in. Why risk grinding your gears?
Old Jul 19, 2005 | 09:29 AM
cefiro8701's Avatar
wow...even if ur lazy stay away from an auto...
Old Jul 19, 2005 | 10:58 AM
kormax97
am i the only one laughing my **** off when i saw the title.. har har har...
Old Jul 19, 2005 | 04:44 PM
DAVE Sz's Avatar
Hooooooonda.....
I guess everyone else is mature enough not to laugh at it.
Old Jul 19, 2005 | 07:36 PM
MaxHijau's Avatar
Man, take it easy. why the flaming? i'm just asking if it good or bad....
plus i have been driving auto for quite a few years and now back to stick...tats why the question came up.
Old Jul 19, 2005 | 07:41 PM
DAVE Sz's Avatar
Hooooooonda.....
The question should have never came up in the first place.
Old Jul 19, 2005 | 08:18 PM
madnut's Avatar
leave the poor dude alone :P
Old Jul 20, 2005 | 01:56 PM
Brudaddy's Avatar
Exactly^^^
BTW....Maximus_95 still has one of the best looking color/wheel combos on a max. Lookin' good, man.
Old Jul 20, 2005 | 02:05 PM
njmodi's Avatar
Do I get a tax break?
Heh heh...: did that sound funny to anyone else?
Old Aug 7, 2005 | 01:36 AM
Bruin's Avatar
Old Aug 7, 2005 | 01:43 AM
FishyMan's Avatar
You dont' wanan ride your clutch or have any premature wear, or replace bearing or clutch every 10k, or mess things up. Paritally engaged clutch, or not putting it in gear fully, or etc. etc. can lead to bad things...
What you do is, find the engagement point, and depress FULLY at least PASS the point, i mean it goes hand in hand. You can tell what's a smooth shift and what's a bad jerk, pop out. So make sure, in all situations depress PASS that engagement point, but that is, depress fully, SHIFT_, release slowly till it grabs smoothly and your good to go.
Old Aug 7, 2005 | 01:52 AM
FishyMan's Avatar
Since we are talking stick and I don't mean to hijack. How many of you hold the clutch in while moving in traffic or tight spots?? or in any 'particular situaiton'?
For example ur in 4th cruising, and you see traffic. What do you do?
You let your car slow down and u downshift to 2nd b4 revs too low, then N and let it roll to stop??
I am curious, cuz this friend of mines does CHOKE engine braking and I'm like WT heck?? Maybe its just my inexperience. I don't know much, but I do know that jolts and jerks are NOT NORMAL, rather I would coast, then brake if needed while downshifting mostly into 2nd, and then reaching N (prior to surging out) to a roll stop. The reason is, I was told that the ONLY TIME you ever press your clutch is to SHIFT< period >. Any excess extended duration of holding in of the clutch while reving, moving, is bad??
Thanks. Still trying to sort out diff't ideas and seek tips as to what is right or wrong. Cuz I taught myself stick, and that's just my consensus.
Old Aug 7, 2005 | 02:20 AM
maximilia's Avatar
dang....I feel cool to drive an auto after that comment.....dang....
Old Aug 7, 2005 | 03:22 AM
madnut's Avatar
Holding the clutch is not bad, you arent killing the grears you are just wearing the clutch out. In my opinion best way to go when slowing down is press the clutch slow down and then shift to approprite gear, choaking the engine while breaking in high gear is very bad for tranny you can even smell the transmission fluid burn when you do that. I ride the clutch in traffic becaouse the maxima is just too jerky in 1st so i shift to second and hold the clutch slightly engadged... even thou this should ware the clutch faster I havent expirenced any exsessive clutch ware on a car that i did that every day for 5 years (nissan stanza).
Old Aug 7, 2005 | 06:05 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
research "Clutch Stop"
Old Aug 7, 2005 | 09:54 AM
goodbye15's
its real easy to adjust the clutch pedal to engage where you want it to and then adjust the height of the pedal so you have just a lil bit of freeplay.
Old Aug 7, 2005 | 12:30 PM
MaxHijau's Avatar
Geez, I almost forgotten about this thread.
That's exactly what I was asking for. Thanks man.
For those who wanted to flame or gave some comments, I suggest you to back to ENG101 class and read what exactly the question was.
ToXIc
Feb 28, 2012 07:21 AM
Guinader
1/4 and 1/8 Mile Racing
Mar 4, 2006 08:46 AM
MAX0830
24
Jun 10, 2004 03:17 PM
THX
23
Aug 3, 2003 12:35 AM
