Help! Starting Problem
Old Jul 20, 2005 | 09:40 AM
oofzpumba's Avatar
My car has the viper v79v alarm. My car will not start. i do not even hear a crank. anyone can you gus help me? THANKYOU IN ADVANCE.
Old Jul 20, 2005 | 09:46 AM
Maxima lover
Did you hook up your alarm or have it professionaly done. It may also be your starter solenoid. Thats the problem I had when I would turn the key to start and hear nothing. Good luck.
Old Jul 20, 2005 | 09:49 AM
oofzpumba's Avatar
i had my alarm professionally done its been working for a long time
i had this problem before but i just got lucky and it started working again. but this time no luck? anyone have any idea? i DONT HEAR ANYTHING! when i try to ignite
Old Jul 20, 2005 | 09:56 AM
njmodi's Avatar
Do I get a tax break?
1. Do the lights/radio etc. work?
2. Do you hear even a click when you turn the key to start the car?
Old Jul 20, 2005 | 10:00 AM
oofzpumba's Avatar
yes i hear a click. and thats it. PLEASE HELP! radio and everything works.
Old Jul 20, 2005 | 10:01 AM
oofzpumba's Avatar
very light sound of a click.
Old Jul 20, 2005 | 10:03 AM
njmodi's Avatar
Go bang on your starter with a piece of wood or a long extension - and then try to start the car again.
If it still doesn't start, it's most likely your starter.
shmad's Avatar
do you have a toggle switch somewhere that u can turn off the alarm? do u know where the power wire for the alarm is at? same thing happened to me on another car. although on the alarm i had, the car would crank but not fire. see if u can disconnect the power to the alarm under the hood. good luck
Old Jul 20, 2005 | 10:06 AM
smokeyone's Avatar
10char
Old Jul 20, 2005 | 02:10 PM
Maxima lover
Take your stock intake pieces off and you will see the starter. There is a black wire that goes to the solenoid that is mounted on top of the starter. Unplug it and get a multi-meter and have a friend try to start the car while you check to see if your getting 12V through that wire(the one not connected to the starter solenoid). If your getting power all the way to there it is not your alarm and is definitly your solenoid or the starter itself.
You said you had this problem before right? So it either starts fine(without any nasty noise) or doesn't start at all right?
Here is the link where to find/take off the starter
http://www.motorvate.ca/mvp.php/516
matts95max
Apr 23, 2025 10:44 AM
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
