About to change some pressure solenoids in trans... help please
Old Jul 20, 2005 | 01:05 PM
f550maranello2's Avatar
Basically im changing the line pressure solenoid that just went bad... i need to know if the filter is hard to change cuz i havent dont it yet on this car since i bought it.. next if anybody has replaced the shift solenoid, do you have to take the valve body out as well....? Any input will be great..
Old Jul 20, 2005 | 01:19 PM
bump... anyone
Old Jul 20, 2005 | 01:39 PM
wannaboostbad's Avatar
HP? would that be Hanover Park? cuz i'm from there i drive a rosewood maxima with 17's
From what i've heard the only time u would ever see a trans filter is when u basically split the trans in half **woodfield nissan parts told me** and i would highly highly highly recommend u send the valve body to a reputable trans shop so they can do it for u.
Old Jul 20, 2005 | 04:40 PM
95nissanMax's Avatar
are you sure the solenoids need to be replaced and not the resistor that people use for the "drop resistor" mod. this will throw the same code im pretty sure. i got the same code and im about to put in a new resistor tomarrow to see if that works.
Old Jul 20, 2005 | 07:00 PM
Yea im fron hanover park....uh, the solenoids were diagnosed as bad the drop resistor is fine i checked it out... i have the dealer service manual and from what i looks like its not entirely that bad to replace it but it doesnt explain in detail how..
Old Jul 20, 2005 | 07:07 PM
nick's Avatar
here is good write up , just follow pics and it should be pretty easy ,
make sure that you install those " lip seals" corectly , otherwise tranny might shift funny, keep the area clean and don't overtorque oil pan bolts - or tranny will leak.
clean the pick up magnet and wire mesh screen ( filter) with brake cleaner
http://www.vqpower.com/v2/modules.ph...howpage&pid=60
Nick.
Old Jul 20, 2005 | 07:17 PM
Hey thanks man that is what im looking for....
Not to change the post or anything but, i see there is a good amount of us here from chicago... we should have a meet some weekend..
Old Jul 20, 2005 | 07:27 PM
2 Da Max's Avatar
wtf? split the tranny in half? wtf are you talking about?
ok take off the 21 bolts on the tranny pan. then youll see a black box, take off the 7 bolts from there and the filter is in there.
check the fluids and lubricant section for detailed piz
Old Jul 20, 2005 | 07:29 PM
nick's Avatar
there is lot of us meeting this Sat(23rd) for THT's 5speed swap, check regional forums for more info.
Nick.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
bumpypickle
Sep 20, 2015 08:22 AM
thenewguyy
Sep 12, 2015 11:12 AM
