Crankshaft Positioning Sensor
Old Jul 22, 2005 | 04:04 PM
wahoohead's Avatar
Has anyone had any experience with the code (0407). I am getting this in conjuction with 0304 (knock sensor) . Gas mileage is normal, starting might be a little bit hard, but nothing I would have noticed.
I had the CEL go on a year ago, (before I could access this site) and the dealership said it was the rear o2 sensor. I replaced that and checked the codes a couple of days ago and get the above codes.
Any experience and thoughts concerning this code would be appreciated.
Old Jul 22, 2005 | 04:09 PM
jackiss2888's Avatar
holy crap, that is the exact same problem i am having same codes and everything, but i installed an udp. wow, that is such a coincidence.
but yea, ANY help would be greatly apprciated. I'm just happy to hear I am not the only one with this problem... sorry you got it too though...
Old Jul 23, 2005 | 06:46 AM
wahoohead's Avatar
What is a udp???
Old Jul 23, 2005 | 06:50 AM
THT's Avatar
THT
Throbbing member
Underdrive pulley. AKA a mod that costs close to $100 and has 0 gains.
Old Jul 23, 2005 | 06:51 AM
mansurxk's Avatar
Originally Posted by wahoohead
What is a udp???
go read the stickies
Old Jul 23, 2005 | 09:42 PM
chenzarino's Avatar
if your crankshapft position sensor was failing, your car wouldn't even start. probably needs to be cleaned. THere are 2 of them, one on the bell housing of the tranny and one, you guessed it, under the pulley.
Old Jul 24, 2005 | 07:01 AM
wahoohead's Avatar
procedure??
Maybe wishfull thinking, but is there any way to just spray brake cleaner in the general direction, and have it actually clean up? or is this a remove and clean with rags and solvent. More detailed advice would be appreciated.Thanks.
Old Jul 24, 2005 | 07:14 AM
mansurxk's Avatar
....no that problaby woulndt be a good idea. pull the snesor and clean it, ones to the right of the oil filter. 2-10mm bolts. take off the harness and pull the sensor and clean it up. the other is under the car. follow the o2 sensor wire and itll be attached to the harness on the tranny i think.
Old Jul 24, 2005 | 12:29 PM
umm, not true, cuz mine is failing and my car starts perfectly fine, however it does have an effect on RPM smoothness...
Old Jul 26, 2005 | 01:19 PM
wahoohead's Avatar
covered in metal powder
Just removed mine ( the one by the oil filter) the sensor spot was covered in fine metal (ferrous) particles, like one would find on an magnetic oil plug. Wiped it off put it together and reset the ecu. Lets see if that was all the fix it needed.
Old Jul 26, 2005 | 01:27 PM
NmexMAX's Avatar
dot dot dot ...
You may have hard starts every now and again, but it WILL start... I repalced mine alst year (CPS)
It's $60 from www.pinnaclenissan.com, make sure you get the right one.
waroohead ... you sure it was Fe?
Old Jul 26, 2005 | 01:46 PM
wahoohead's Avatar
I guess
It was magnetically stuck to the tip of the sensor that faces the flywheel. I brushed it off with a paper towel, and a soft cotton rag. It felt like metalic particles, and it surely was stuck magnetically.
Now that I have someone elses interest, where is the other one bolted crankshaft positioning sensor?
Old Jul 26, 2005 | 01:49 PM
NmexMAX's Avatar
dot dot dot ...
Near the flywheel .... But read the stickys, and buy a Haynes, that will help decipher which one you need to repalce (REF) (POS) I forget which is which
Old Jul 26, 2005 | 02:44 PM
wahoohead's Avatar
I have the factory manual
Poor as it is the factory manual refers to two different crankshaft positioning sensors. One sensor has two bolts and is by the oil pan and reads off the flywheel. That one the factory book refers to as a CKPS (POS) (DTC:P1336) the other sensor aooears from the crappy pictures to have one bolt holding it on ot (WHERE)?????. It is also call a CKPS POS but the next part is different (DTC: P0335).
The second sensor is imaterial because I can't find it.
Now a little more info. After cleaning the two bolt sensor. I went on a test drive and when through about 7 start cycles, and so far no CEL. We will see with another day of normal usuage. although it would usually show a CEL after a reset within about two or three start cycles.
But if anyone knows where the one bolt sensor is I sure would clean it also.
I swear I have read every sticky at least three times.
Old Jul 26, 2005 | 02:47 PM
njmodi's Avatar
Do I get a tax break?
The second CPS is in the tranny bell housing - right near the flywheel.
Old Jul 26, 2005 | 02:51 PM
Jeff92se's Avatar
I'm needing a caw
What is usual fix? Does cleaning these sensors usual fix a hard start? Or does replacing them more of the common result?
Old Jul 26, 2005 | 04:08 PM
wahoohead's Avatar
I found it!!!
I think I found it. By the center frame piece underneath a plastic guard( with about 4 screws to remove it )sitting all by itself on the bell houseing. with one bolt to remove it. I decided not to remove it untill I get the CEL light on again and the right code (0407 I think it was) .
Still no CEL and I am sick of looking at the underside of a Maxima, so no more fooling with the crankshaft sensor POS. And does anyone else think it is strange that Nissan chooses to use the letters POS for one of their parts. I always thought POS stood for piece of sh**.
Old Jul 26, 2005 | 04:25 PM
njmodi's Avatar
In this case, POS = Position, REF = Reference.
Old Jul 27, 2005 | 06:33 AM
wahoohead's Avatar
CEL on off on off on off
Finally the CEL came on then went off then on etc. I am going to put dielectric grease in both conections, and hope that it is a connection problem rather than a bad sensor. It seemed to go on or off after bumps. And yes I really do have the connection on untill they click. It is a good thing that the CEL problem doesn't seem to make it run poorly.
Old Jul 27, 2005 | 07:17 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
will a bad crank sensor affect automatic shifing?
Old Jul 27, 2005 | 08:51 AM
chenzarino's Avatar
These sensors are just magnets, hard to see how they go bad.
Old Jul 27, 2005 | 09:00 AM
killcrap's Avatar
two ways to destroy a magnet. heat it or beat it. yeah, i guess the engine block is never hot. nor is there any turbulance.
Old Aug 5, 2005 | 07:32 AM
wahoohead's Avatar
Update
Well I cleaned the metalic particals off the sensor and now the car won't start. So I ran down the battery, and put it on the charger overnight and it was still charging high after 10 hours, which leads me to believe that the battery is bad, and maybe that is why it won't start, i.e. not cranking fast enough.
I seem to be going backwards, put a knock sensor in put a rear o2 sensor in, pout plugs, cleaned the butterfly, checked the air filter, changed the fuel filter, and it went from hard starting to no starting. Anyone got any ideas? Next I will order the crank sensor. I will also push it out and try to jump start it with some help from starting fluid.
Old Aug 5, 2005 | 07:36 AM
njmodi's Avatar
So now your car cranks, but won't start?
Did you reset the ECU. I think its time to replace the offending sensor. Pull the codes - if you are still seeing 0407 let us know.
Old Aug 5, 2005 | 07:51 AM
wahoohead's Avatar
I did reset
and the codes came back. I then replaced the knock sensor, (with a combo 1/4 inch socket swivel it was pretty easy). I also put some dielectric grease in the connections after it wouldn't start. Just got off the Pinnacle Nissan site and order the crank sensor. Next week I will replace it, (a ten minute job).
Any other ideas? I have not checked codes since the knock sensor was put in or ofter cleaning the crank sensor. Don't think it would matter because the engine has not started since. That actually should be a clue, pull sensor clean put back in car won't start, HMMM?
Old Aug 5, 2005 | 07:52 AM
njmodi's Avatar
Nope - you are doing the right thing. You ordered the correct CPS right? (since there are two different ones).
Old Aug 5, 2005 | 07:55 AM
wahoohead's Avatar
only one in the catalog
Only one shows up in the catalog. I know there are two but I only messed with one and the Pinnicle catalog only shows the one. Hell at this point I'd order both, along with o2 sensors even though I never got that code (front o2), but I will be somewhat methodical in this.
Old Aug 5, 2005 | 07:56 AM
njmodi's Avatar
Is 0407 the POS CPS or REF CPS (I'm too lazy to look it up).
Old Aug 5, 2005 | 07:59 AM
wahoohead's Avatar
I'll do the footwork if you have the advice!
it is the reference
Old Aug 5, 2005 | 08:12 AM
njmodi's Avatar
REF is the one with two bolts right under the crankshaft pulley (above the oil filter).
Old Aug 5, 2005 | 08:28 AM
wahoohead's Avatar
That is it
That is the one I have been messing with. So I guess I have ordered the right part, and hopefully it will start.
I do think my battery is weak. After a full overnight charge it reads12.5 volts.
I think thats weak.
Old Aug 7, 2005 | 08:15 AM
killcrap's Avatar
12.68v is fully charged. whats the specific gravity of all the cells.
1.265 is fully charged at 70 degrees.
Old Aug 7, 2005 | 09:53 AM
wahoohead's Avatar
Pulled battery
After a charge of about 24 hours the battery cranked for about 5 seconds, and that was it. I think I have a shot battery, and will take it in for testing. No cells to check it is a sealed battery. Glad I have another vehicle, (although it is a truck and gets 12-15 MPG around town),
Next on the list of things to buy is a battery load tested. Available on EBAY for $10-15. I hate pulling the battery and hauling it to town.
Old Oct 1, 2005 | 07:33 PM
95PRMax's Avatar
ok well i been dealing with this problem now for two days......after a long and hard battle explanation at the link below
http://southfloridamaximas.com/forum...read.php?t=660
i have gotten the code 0407........and if anyone else has any ideas please let me know........
come to conclude my mechanic says its the fault of the wrong sparkplugs that led to this and i am writing up a letter to the performance shop that sold them to me and they will pay for all my damages and fees.......so i will be changing the crankshaft sensor tomorrow and post up on what happens......the car starts barely but it just bogs out and sputters....so yeah
Old Oct 2, 2005 | 08:27 AM
wahoohead's Avatar
spark plugs?????
I can't imagine the plugs (almost any plug ) would have a big effect. My problem ended up bing multiple, starter, battery, knock sensor, fuel filter & crankshaft sensor. When I could get mine to start it ran ok, but now with all the various sensors replaced, (and an o2 sensor) it definetly runs faster and smoother with a small increase in milage. So my advice and best guess is replace all the coded sensor problems and then see what happens.
Old Oct 2, 2005 | 08:38 AM
95PRMax's Avatar
wellt his morning i pulled the ngk spark plug that i had put in last night from the same place from the rear center spark plug area and this morning i pulled it out and the little rode that extends and teh electrode are once again smashed.....................my piston and everythign else are pretty much screwed up and my timing along with the chain and the teeth............
i talked to a nissan tech or mech i mean and well due to my car running extremely rich the piston jumped smasshed the iridum plug causing my whole timing to go off and everything....all this b/c of the wrong spark plug.......i am currently getting an attorney and any other outcome i am not please.......a ruined maxima over this....welll thanks guys for everything...
as for the ngk i remvoed today it had green gunk on it.....and metal shavings from what was the old spark plug in it......
Old Oct 2, 2005 | 08:45 PM
wahoohead's Avatar
start from the beginning
Start this story from the beginng clearly. If the wrong plug was put it the only thing that could happen (if it was too long) would be piston interferance. I could be wrong but I doubt any plug even one too long would hit the piston, but on that point I am not sure. As far as screwing up the timing and the camshaft chain. I doubt it. Hope someone else chimes in. If not start this as a new thread with an interesting title and see what happens.
Old Oct 3, 2005 | 02:19 PM
95PRMax's Avatar
well two nissan techs said the cause was of the spark plug being to long and the wrong one and it fried my piston completely causing it to break and y head gasket is gone.....as well so thats it for the vq30 in my car
my dad and i are seaking attorney and taking legal matter
thanks for everythign guys.......
who knows maybe if i get moeny vq35 going in
Old Mar 10, 2006 | 03:31 AM
smaye's Avatar
In reading the stickies I saw a flow chart for intermittent starting referring to a "POS COINT NOT 180".
How do I check the POS COUNT?
TallTom
57
Oct 14, 2025 05:16 PM
hayne
Oct 5, 2015 11:53 AM
salty318
Sep 28, 2015 07:22 PM
zmcneely13
Sep 26, 2015 02:26 PM
