5th Gen Tranny advice
I am going to buy a new tranny and am wondering what would be the best buy for an LSD 5 speed tranny. should i go with the 5th gen or the I30 and also if anyone has any good prices on this item or anywhere in New England who might have one that would help alot. Thanks
www.car-part.com is your friend. Go with the 5th gen. Stronger third gear.
Go with the I30 lsd. I have read some posts that the ae tranny will throw your speedo off because it used a different speed sensor. Plus this talk of the 3rd gear being stronger (not as in it pulls harder as the ratios are the same) is (as far as I can tell) speculation.
With the I30, all you need are lsd axles and your set. Everything is a direct swap.
Originally Posted by MDeezy
I believe both are pretty hard to find as is. I saw go with the 5th gen seeing how the I30s were subject to the bearing faulire like the rest of the 4th gens.
Originally Posted by i30ds
The 5th gens have the bearing failure too.
Arent they less likely than the 4th gens to get it? I sure hope not, I dont want to have to swap out my tranny as after as I would platinum sparks.
I dont think they are less likely to occur in the 5th gen. The reason it is just now croping up for them is the fact that a lot of thes guys are just now getting to the milage point where the problem occurs. As time goes on we will be able to tell or not.
6 speed tranny will work, but it is by no means bolt on. Only 2 people have done it and they said it wasn't worth it. Converting to cable shift is a major pain and I am not sure if the flywheel is the same.
5th gen 5 speeds do have a stronger 3rd gear. Those who have taken it apart have seen it to be physically larger. I believe Nissan also said they made the 3rd gear syncro better too. I am not sure about the bearing problem.
IMO the VLSD is cool and all but I would rather a stronger third from a 5th gen then just the LSD from a A32 I30. The VLSD will not make your traction problems go away.
If you really want to you can use the internals from a 00-01 Altima and get shorter 1st, 2nd and 3rd, same 4th and taller 5th, but you have to put all the Altima internals into the Maxima housing. The Altima 3rd gear is stronger too I think.
pktaske
05-06-2016 07:49 AM
pktaske
09-04-2015 08:40 AM
