How does one program their garage door opener for a 99 SE-L?
Old Jul 25, 2005 | 12:00 PM
dki378's Avatar
I was wondering if anyone knew how to program the garage door opener on the drivers side visor to work with your home garage? Thanks in advance!
Old Jul 25, 2005 | 03:28 PM
4x4Max's Avatar
I never figured out how to do it in my 98 either.
Old Jul 25, 2005 | 03:40 PM
JwaxMax99's Avatar
I can't figure it out on my 99 either. And I followed the pullout instructions that come with owners manual....
Old Jul 25, 2005 | 03:58 PM
dahman45's Avatar
i think if you have a newer garage, u have to hit teh "learn" button on the actual motor, but i tried doing that and still had no luck....but u could try and look for that button
Old Jul 25, 2005 | 04:07 PM
Loe max's Avatar
IIRC off the top of my head, you press the two outer bottons to 'clear' the system. Then you press whichever one you want to program and it will start to blink slowly. Hold it down and hold up the garage door opener next to it pressing its botton until the light starts to blink quickly. Now its programmed.
BUT if you have a garage with a rolling code, now is the time to press that botton on the garage door motor. You have 30 seconds to do this, or you will have to repeat the first couple steps again.
Old Jul 25, 2005 | 05:10 PM
sunten1
Ya its something like that, I did it to my 98 a long time ago...
And the funny thing is that I get better range then actully garage door opener...
Old Jul 25, 2005 | 06:15 PM
Loe max's Avatar
Nissan's have one of the best remote rangings I've seen , I'm jealous everytime I hit my homelink and or keyless FOB on my current car and nothing happens until the last 15feet
Old Jul 25, 2005 | 07:04 PM
RA030726's Avatar
I'm nutty for Nissans
i listed the directions in the how to's. take a peek.
Old Jul 26, 2005 | 08:07 AM
dki378's Avatar
Maybe I'm looking in the wrong area... but I don't see anything in the how-to's for anything like this. Can you provide the link? Thanks.
Old Jul 26, 2005 | 09:17 AM
4x4Max's Avatar
http://forums.maxima.org/showthread.php?t=320939
Old Jul 26, 2005 | 09:19 AM
DcMaN's Avatar
CAUTION!
Before programming HomeLink to a garage door opener or gate operator, make sure that people and objects are out of the way of the device to prevent potential harm or damage. Your motorized garage door or gate will open and close while you are programming HomeLink. Do not program HomeLink if people or pets are in the path of the door or gate. A moving garage door or gate can cause serious injury or death to people and pets or damage to objects.
Vehicle exhaust contains carbon monoxide, a dangerous gas. Do not run the vehicle's engine while programming HomeLink. Exhaust gas can cause serious injury or death. When programming a garage door opener, it is advised to park outside of the garage.
Do not use HomeLink with any garage door opener that lacks safety stop and reverse features as required by U.S. federal safety standards (this includes any garage door opener model manufactured before April 1, 1982). A garage door that cannot detect an object signaling the door to stop and reverse - does not meet current U.S. federal safety standards.
NOTE: Some vehicles may require the ignition to be turned on or to the second (or “accessory” or ACC) position for training and/or operation of HomeLink. It is also recommended that a new battery be replaced in the hand held transmitter of the device being trained to HomeLink for quicker training and accurate transmission of the radio frequency.
1. For first time training, press and hold the two outer HomeLink buttons, releasing only when the HomeLink indicator light begins to flash after 20 seconds. (Do not perform this step when training the additional HomeLink buttons.)
2. Position the hand-held transmitter 1-3 inches away from the HomeLink surface (located on your visor), keeping the HomeLink indicator light in view.
3. Using both hands, simultaneously press and hold both the desired HomeLink button and hand held transmitter button. DO NOT release until the HomeLink indicator light flashes slowly and then rapidly. When the indicator light flashes rapidly, both buttons may be released. (The rapid flashing indicates successful training.)
Note: Some garage door openers may require you to replace step 3 with the “cycling” procedure noted in the “View Canadian Instructions” section.
4. Press and hold the trained HomeLink button and observe the indicator light.
If the indicator light is solid/continuous, training is complete and your device should activate when the HomeLink button is pressed and released.
If the indicator light blinks rapidly for 2 seconds and then turns a solid/continuous light, proceed with the following training instructions for a rolling code device. A second person may make the following steps quicker and easier. Please use a ladder or other device. Do not stand on your vehicle to perform the next steps.
5. At the garage door opener receiver (motorhead unit) in the garage, locate the “learn” or “smart” button (usually near where the hanging antenna wire is attached to the unit). If there is difficulty locating the training button, reference the garage door opener’s manual or contact us.
6. Press and release the “learn” or “smart” button (the name and color of the button may vary by manufacturer). NOTE: Once the button is pressed, there are 30 seconds in which to initiate the next step.
7. Return to the vehicle and firmly press and hold the trained HomeLink button for two seconds and release. Repeat the “press/hold/release” sequence up to 3 times to complete the training process.
HomeLink should now activate your device.
Retain the original hand-held transmitter of the RF device you are programming for use in other vehicles, as well as for future HomeLink programming. It is also suggested that upon the sale of the vehicle, the programmed HomeLink buttons be erased for security purposes. To erase the programmed buttons, perform the procedure shown in step number 1.
**To train additional HomeLink buttons, begin with step two.
Indicates that this instruction is important to follow for reasons of personal safety, and that failure to follow the instruction could result in bodily injury.
HomeLink is intended to be used only with HomeLink compatible products that are programmed consistent with the applicable instructions on our website at www.homelink.com. Those instructions and product listings indicated by the symbol are particularly important for avoiding damage to the programmed device and other property associated with that device. Failure to comply with instructions or product listings can result in unwanted property damage. Johnson Controls is not responsible for property damage that results from failure to follow instructions or product listings indicated by the .
Start Over
Old Jul 26, 2005 | 09:31 AM
dki378's Avatar
Awesome! Thanks!
Old Jul 26, 2005 | 12:53 PM
TJ_Max's Avatar
Paradox Systems Vendor
im gonna try new batteries, i consider myself good with electronics and directions, and this shyt still doesnt work... after new batteries im giving up..
REDinLV
Aug 15, 2024 12:30 AM
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
BobTX10
Oct 7, 2015 08:43 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
