Adjusting Idle RPM's
Old Jul 27, 2005 | 08:36 AM
smokeyone's Avatar
I'm sure this is here somewhere, but i couldn't find it. How do you adjust your idle? I changed spark plugs a few weeks ago, and since then, at startup the rpm's only go to 1200 instead of 1500, and the car feels a bit sluggish. At idle, it's around 600-700 like normal. Oh, and I did put in NGK coppers, the correct ones, so its not them.
Old Jul 27, 2005 | 08:39 AM
njmodi's Avatar
Do I get a tax break?
If the warmed up idle (base idle) is at 600-700, then there is nothing for you to adjust (i.e. it doesn't need adjusting).
Old Jul 27, 2005 | 08:40 AM
Bobo's Avatar
What makes you think you need to adjust your idle? At operating temperature your idle at 600 -700 is normal. If it ain't broke don't fix it!
Old Jul 27, 2005 | 08:41 AM
njmodi's Avatar
Beat you to it Long time no see... hows the ARX treating you? (OT I know).
Old Jul 27, 2005 | 08:42 AM
smokeyone's Avatar
Hmm. I was thinking that. So what could cause the idle at startup only going to 1200 instead of 1500?
Old Jul 27, 2005 | 08:44 AM
njmodi's Avatar
It's warmer outside. That is what affects where the idle starts off at. When the car is COLD, the idle is going to start higher than when it is warm (either because of the ambient temperature or because it was recently driven).
Old Jul 27, 2005 | 08:45 AM
smokeyone's Avatar
Wow. Learn something new everyday. Thanks for the quick replies.
Old Jul 27, 2005 | 08:48 AM
bojo2004's Avatar
Can someone tell me what the spark plug gap is for 97 max, thx
Old Jul 27, 2005 | 08:49 AM
njmodi's Avatar
No. Can someone please read the stickies.
Old Jul 27, 2005 | 08:51 AM
turbo
Mine is about 900 when warm, is there a FAQ on how to adjust it?
smokeyone's Avatar
Its the same as the gap on the 95, 96, 98, and 99.
Old Jul 27, 2005 | 08:52 AM
njmodi's Avatar
It is in the stickies.
Old Jul 27, 2005 | 08:56 AM
konak85's Avatar
.044
10 char
turbo
Yeah just came across it, and JR nissan was the only ones carrying the OEM mats. $75US shipped. Thanks!
Old Jul 27, 2005 | 08:59 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
i love how people say they have a high idle problem, and then people suggest , oh hey, just read the stickys. and some people even say adjust your idle at the screw in the engine compartment.(99 on ecu) but the real problem with that is, if you didnt adjust it before or mess with it beofre, 99% of the time its a serious problem that has occured like a vacum leak. oh lets just adjust the idle to fix that problem... jeez
Old Jul 27, 2005 | 09:00 AM
njmodi's Avatar
to that
killcrap - with a vacuum leak, will your warmed-up idle end up settling at the 550-650 spec? I think that with a vacuum leak, you'll have a constant high idle...
Old Jul 27, 2005 | 09:11 AM
killcrap's Avatar
if your reffering to a standard transmission, that spec is correct. but if it did have a vacuum leak the o2 sensor will see that, and will relay the infor to the ECM, and the ECM will command rich. and the Rpms will have a contant hig idle.
i'm reffering to the post above where his idle is 900rpms. most likely a small vacuum leak. get a scan tool and check the LTFT you can ignore the STFT.
Old Jul 27, 2005 | 09:28 AM
sdoherty_tjm's Avatar
and since someone mentioned the temperature, thats why your car is sluggish, its ****in hot out
Old Jul 27, 2005 | 09:43 AM
bojo2004's Avatar
I was looking in the stickes first and still cant find it
Old Feb 21, 2008 | 05:49 PM
FishyMan's Avatar
I've cleaned my TB and etc, and mines a round 900 and less. I never recalled seeing it this high b4.
Old Feb 22, 2008 | 01:32 PM
NmexMAX's Avatar
dot dot dot ...
Jesus, do you realize how old this thread is? It will be a little high after a TB clean. I use my ECU screw to adjust mine. I'm at about 850 or so.
Old Feb 23, 2008 | 06:19 AM
njmaxseltd's Avatar
1) Fast idle linkage or plunger broken or out of adjustment
2) Clean your TB
3) Check the resistance of the ECT sensor
Old Feb 23, 2008 | 11:11 PM
NmexMAX's Avatar
dot dot dot ...
errr ahhh, my guess is that he already solved his problem, being 3 years ago and stuff.
tarun900
19
Dec 20, 2021 06:57 PM
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
