17in rims and tires
Old May 22, 2001 | 08:23 PM
euromaxima's Avatar
Should i get 16 or 17in rims? If i get 17 what kind of tire should i get so that i wont blow one when i hit a pot hole or bend the rim when i hit a pot hole? Plus would the 17 in tire rub anything when i turn. What are some good affordable tires to buy?
thanks Brandon
Old May 23, 2001 | 07:31 AM
ny96max's Avatar
well look at my signature pic, i have 225/45/17's on Konig Monsoons. NO rubbing, not too bad on bumps either. My boy Joe with his 96max has the same tires but different rims on a stock suspension and the car feels the same as it did with stock rims on it.
If your that worried about bumps, you can easily fit 225/50/17's on 17" rims in the wheel wells. But then you loose the "sport look"
my .o2
hope that helps...
Old May 27, 2001 | 02:04 AM
Oceaner's Avatar
I have 17" rims and tires
I have Enkei's new Arashi 17 x 7 rims (19 pounds) and Yokohama's AVS db 235/45/17 tires ( made to give a quieter ride )
and no, they don't rub the walls, but they do take more energy from your engine.
Old May 27, 2001 | 07:56 AM
danielbu's Avatar
17"
Go with the 17" rims, definetly. I was wrestling with the same decision a year ago. After a year, I have been very happy with my choice of Enkei RP02 rims and 225/45/17 Pirelli P7000 supersports although the pirellis live up to their stereotype of fast wearing (Khumhos next). The look is great, no rubbing under any condition, and the ride is still very tolerable given the performance trade-off. Make the right decision, go with 17"
-Dan
Old May 27, 2001 | 09:24 AM
Micah95GLE's Avatar
thanks Brandon
Get 17x8s with 235/45ZR/17 tires.
Old May 27, 2001 | 12:23 PM
BobMax's Avatar
How are the roads where you live ?
Are you driving on some nice flat LA roads ? Or hobnobbing it down the potholes of Boston ? 17" wheels look nice but _will_ bend in the pothole regions of the country. Not "might", but "will". You have to run the pressure high to preserve them and that leads to a bouncy, hard ride with less control. They will also reduce acceleration if you are a performance hound. 16" is a better all around choice. But, if we made all of our choices based on security and safety, there wouldn't be any other mods happening around here.
later,
Bob
Old May 27, 2001 | 12:47 PM
dch95's Avatar
Answers.
thanks Brandon
If you have already lowered your car, the 17s will hurt more so than the 16s. I have almost a 2 inch drop and the 17s can really be felt esp in the front end. I borrowed som 15s from a friend to get the front end aligned and WOW! What a difference it made! The lower the profile on a lowered max makes a BIG difference.
Old May 27, 2001 | 06:58 PM
riggy's Avatar
opinion
i want to get kumho escata tires with 17 inch adr gt rims. whalentire says they mount and balance them. should i expect any troubles. any input greatly appreciated.
Old May 27, 2001 | 07:18 PM
metallic97gxe's Avatar
Master Will
Re: opinion
SHADOW on Here has the big 19"s they look good too...I think we three will be the only ones with these wheels...on here
I got mine from them too...
here...
ADR(ADVANTI DESIGN RACING)GT-Sport Silver-15x6.5"=$400.00 set-Whalen Tire.com. On 205/65R15 Tires
yes I only have 15" size but they only weigh 15lbs. each...very easy to spin,better gas mileage...and easier for the engin to turn...
http://www.whalentire.com/
I have silver what color are you getting?
Old May 27, 2001 | 10:50 PM
abnorm's Avatar
How harsh is the ride with those???
Old May 27, 2001 | 10:56 PM
Kashoggio's Avatar
go with 16's , 17 are too heavy and the tires are a little more money. I have 17 and I wish I would have gotten 16, better ride, not so harsh and still looks fine.
Old May 28, 2001 | 02:20 AM
BrianV's Avatar
I got 17's and think they're perfect. Handling is improved, accelleration isn't affected, looks are improved, ride is about the same. I recommend 235/45/17 for tire size.
Old May 28, 2001 | 09:34 AM
danielbu's Avatar
17" & Hard roads
Ok, my setup is as follows:
Eibach Springs
Tokico Struts
17" Enkei RP02
Pirelli P7000 Supersport 225/45/17
I have extensive experience running these on the neglected streets of Philadelphia, and as long as you use reasonable discretion in negotiating the potholes and etc, you shouldn't have any problems. I have yet to bend a rim or blow a tire. Yes the ride will be more harsh, and you will have to pay more for tires, but what are you trying to accomplish? If you are trying to get the most out of your Maxima and the modifications you have made, then the 17" are the way to go. If you are going purely for looks and are trying to save cash and sensibility, then the 16" are probably the way to go... In the end, it is up to you and how far you are trying to go. Personally, I know that I would end up kicking myself in the *** later down the road if I got the 16". Hope this helps.
Dan
Old May 28, 2001 | 10:00 AM
Kashoggio's Avatar
Re: 17" & Hard roads
Eibach Springs
Tokico Struts
17" Enkei RP02
Dan
so if you have 16 inch rims, they are just for looks?? , ohh yeah and you gain so much more with 17 inch tires.
Old May 28, 2001 | 10:20 AM
MaximaRider's Avatar
i have it bad here
in NJ, i have 18x8 TR Motorsport Sniper rims (21 lbs) & 235/40/18 Kuhmo's. I also have Eibach and Tokico, it is ruff as hell on the NJ potholed roads but the handling is awesome, sure its slower than when i put my 15's on(which i sold) needed more money for tires on the 18's that for sure. All in all i like 18's i think 17's looked to small on the max, def get some 17's if ur thinkin in between 17 and 16.
Old May 28, 2001 | 07:42 PM
Kashoggio's Avatar
i agree that Nj roads are crap.
Old May 28, 2001 | 09:39 PM
shawn69's Avatar
tire sizw
It all depends on where you live, I live in the bronx,nyc.
the roads here are unreal, I went threw 2 concept neepers 17"/45/235 in one year! (bruckner expressway is under construction)I switched to konigs 17"/50/225 & It's a whole new world.Spots where I slowed to 35 I now blast threw at 60, you have to weight your options, what you want according to your area.urban=50 subarbs=45 country=240
I laugh when I see guys with 17"/245/40's slow down to take a bump in the city.The Maxima is a great car and if set up right will handle any situation.Dont build your car to fit the mags, those guy run on perfect tracks & tow there cars home!
just my 2 cents
Old May 28, 2001 | 11:30 PM
AznWontonboy's Avatar
my .o2
hope that helps...
not if u go with nitto450 225/50/17..
Old May 29, 2001 | 07:43 AM
danielbu's Avatar
Just for looks
kash, obviously 16" are an improvement, but yes, 17" do provide more performance as a result of the increased contact patch and shortened sidewall. Do you use premium or super unleaded? Same thing. And if there is little to sacrifice in the way of ride comfort, then I think it is worth it, that is all I was saying.
Old May 29, 2001 | 08:55 PM
Kashoggio's Avatar
Re: Just for looks
you know 16's do come in various sizes and different widths. It all depends on the rim you have. Just because you have a 17 inch rim dosent mean its going to out due a 16 inch rim.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Garrettz459
Sep 28, 2015 02:50 PM
