Service Engine soon light on
Old Jul 30, 2005 | 07:55 AM
DoGGx23's Avatar
Went to my local mechanic today to have my check engine light checked. There are two problems with my engine. First problem is the EGR valve malfunction and the second problem is the knock sensor.
I need your advice on what to do so I can pass my inspection. The mechanic told me to change three parts. EGR Valve, EGR sensor and Knock sensor.
I've researched into this problem before and some people fix the EGR problem by either cleaning out the carbon or changing the part. Since the computer said the EGR valve is malfunction should I just change it? Also do I need to change the EGR sensor?
As for the knock sensor, what is the purpose of it? Is it hard to get it? My mechanic said it somewhere in the manifold and the labor is expensive because he has to disasemble alot of parts in the engine to get to the knock sensor.
As for the EGR valve what else needs to be changed or clean when doing this?
I will be purchasing the part from online since it's cheaper. Where are some good websites that sells OEM parts for cheap?
Old Jul 30, 2005 | 08:36 AM
|Bijan|'s Avatar
UCF Lexus
I *think* the EGR sensor is what usually trips the code.
The KS detects 'knock' or pinging. - It's VERY easy to change if you have a FED-SPEC.
www.pinnaclenissan.com
www.courtesynissan.com
PM to member DAVEB - parts guy
Old Jul 30, 2005 | 09:31 AM
Jatan's Avatar
Fix the EGR stuff first (KS most likely turned on due to the EGR prob)
Old Jul 30, 2005 | 11:06 AM
erty67's Avatar
Decal Specialist
Fix the EGR problem first and reset the ECU. The knock sensor code shows up with just about anything.
Old Jul 30, 2005 | 11:08 AM
Kevlo911's Avatar
Kevlo for President
If you have a 99 I have an EGR vavle to sell
Old Jul 30, 2005 | 11:22 AM
DoGGx23's Avatar
I have a 99 SE how much for your EGR valve? i'm looking to buy a brand new one though cause it's not that expensive.
So I should fix the EGR vavle stuff first right? Just replace the valva and sensor? Can that be done by my self if I had the right tools? What tools do I need and is there an online tutorial on how to do this?
Old Jul 31, 2005 | 05:50 AM
DoGGx23's Avatar
So where is a good and cheap place to buy OEM Nissan parts?
Old Jul 31, 2005 | 07:03 AM
BossMoney's Avatar
ok, MY check engine light just came on..the car runs great, everything works normally..but I think I know what it is..yesterday I got my air filter changed for the first time since i owned the car...and i think some dirt got in the air box..car only has 90k on it..it cant be the o2 sensor yet..any help would be appreciated ASAP i got inspection..TOMMORROW.
Old Jul 31, 2005 | 07:25 AM
smokeyone's Avatar
Did you check your codes? Thats the first step with a CEL.
Old Jul 31, 2005 | 07:47 AM
Jatan's Avatar
http://forums.maxima.org/showthread.php?t=104931
Old Jul 31, 2005 | 08:17 AM
I30tMikeD's Avatar
It is not possible that chaning the air filter would that cause a CEL to appear. There is no sensor for "dirt in the intake".
Having an o2 sensor go at 90K miles is not uncommon either.
You can't do anyting till you check the codes. Look in the stickies, read the discription of your problem and go from there.
Old Jul 31, 2005 | 08:28 AM
erty67's Avatar
Decal Specialist
the man to talk to is JRNissanParts
http://www.jrnissanparts.com/
Old Jul 31, 2005 | 09:34 AM
knight71's Avatar
Your problem is not with the EGR valve itself, Egr valves hardly fail, I too had EGR issues in the past. My problem was resolved by replacing EGR solenoid valve, which is located in the passageway near the KS, very easy to replace, costs about $60-80. If you've never had your KS replaced, chances are this is faulty, again, easy to replace..(read the how to stickies).
Old Jul 31, 2005 | 09:41 AM
MaximaSpd85's Avatar
DO NOT let ur mechanic or any machanic take a bunch of crap apart to change ur knock sensor! they dont neeeed to. if u decide to let the mechanic do it, maybe he'll charge u a whole lot less if u tell him all he needs is a long extension and one of those u joints or wutever u call them. the mechanic probably already knows that but tryin to make a little extra $$$$....but like everyone said its easy
Old Jul 31, 2005 | 05:20 PM
DoGGx23's Avatar
How do I change the EGR Solenoid valve? I found the DIY for the knock sensor but I didn't find any guides for the EGR solenoid. Can some link me please? Thanks
Old Jul 31, 2005 | 05:58 PM
BossMoney's Avatar
its def NOT my 02 sensor..my gas mileage is great..i use 93 octane everyweek, nothing else..the light just came on..a few hours after the dumb**** at the oil change place ****ed with my air filter..and im thinking he mighta ****ed something up...anyone ever have the same kinda problem?
Old Jul 31, 2005 | 06:05 PM
smokeyone's Avatar
Dude, until you check your codes, all you're going to get is blind speculation. Check the codes, post back with them, then go from there. And if the mechanic was messing with the air filter, make sure the MAF and other sensors around there are plugged in.
Old Aug 1, 2005 | 04:16 AM
DoGGx23's Avatar
Can anyone tell me how to change teh EGR solenoid? Where can I buy this part?
Old Aug 1, 2005 | 05:35 AM
knight71's Avatar
EGRC solenoid is located near the entrance of where the KS is, just before . To take this sucker off it's just one 10mm (IIRC) nut underneath. A small wrench will do that.
egr solenoid part # The Nissan part number is 14956-31u10
Here is a pic of detailed location:
http://photobucket.com/albums/v158/e...s_location.jpg
vingodine
45
May 21, 2016 12:46 PM
rbaker100
Aug 28, 2015 08:11 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Flores94
Aug 11, 2015 12:53 PM
