air bag light..
Old Jul 30, 2005 | 08:45 AM
sean05's Avatar
air bag light..
When i was trying ti wire my kill switch i accidently cut one of the airbag wires I connected the wire back together but now it wont go off. Anyone have any ideas? can this be erased with a OBDII scanner?
Also my dads 5th gen SRS light is on but we dont know why. He covered it with electrical tape. haha
can any1 help me out?
Old Jul 30, 2005 | 09:21 AM
Jatan's Avatar
http://forums.maxima.org/showthread.php?t=254238 end of post #2
Old Jul 30, 2005 | 09:25 AM
sean05's Avatar
Originally Posted by JaTaN
i tried that... it didnt work
Old Jul 30, 2005 | 09:29 AM
Jatan's Avatar
Worked for me in the past, what happened when you tried those steps? Have you tried unplugging the battery for a few hours?
Old Jul 30, 2005 | 09:35 AM
sean05's Avatar
not a few hours many 10 minutes. Ill disconnect it 2night when i go 2 bed. Ill go try those step again. It just still blinks.
Old Jul 30, 2005 | 09:55 AM
Jatan's Avatar
When I did it the first time the light kept blinking, but then I did the steps again right away and the light went away when I restarted the car
Try doing the steps 2-3 times (one after another) or by unplugging the battery. If it doesn't go away then something must've gotten messed up
Old Sep 6, 2005 | 12:13 PM
cardana24's Avatar
Blown
what causes the air bag light to blink? I have read about how to reset it but I am curious as to why it even starts blinking? It just started blinking in my 95.
Old Sep 6, 2005 | 12:21 PM
njmodi's Avatar
Do I get a tax break?
The blinking indicates the SRS system has detected a fault during the power on self-test. The fault could be with one of the bags, controllers, etc.
Old Sep 6, 2005 | 12:47 PM
kcryan's Avatar
IF YOUR AIRBAG LIGHT IS FLASHING WHILE YOU DRIVE 9 times out of 10 it is the passenger seat side air bag...the one that is inside of the seat...what you need to do is the following:
Open your door and first locate the button on pillar A....this little button is the drivers door switch and when the door is closed the button is pressed in making the car know that the door is actually closed....it is a small button with black rubber surrounding it. Once you locate it, turn your key to the ON position....DO NOT start the car...simply turn the power on so the engine light, battery and everything else is lit without engaging the ignition. Then with the key in the ON position press the drivers door switch at least 10 times within 10 seconds with your finger: in and out in and out fast......then once you have done that turn your key to the OFF position....when i did this I found it easy to turn the key half way between where you take it out and half way between ACC so nothing should be getting power...not even the radio but you should also not be able to pull the key out. Then close your door and with the key in that same position, between taking it out and ACC, start the car by turning it towards the ignition. This means don't take the key outta the ignition the whole time.
If you have a 99 9/10 it is the passenger SEAT airbag....the one that is actually in the seat and Nissan will try to tell you it is faulty but by doing this you will engage the system so it will work again. I know people that have had the seat air bag repaired and then the light has come on within a year. If it was the airbag that was in the dash I would say get it fixed but with it being a seat air bag even if it doesn't work the rest of the system will. Same thing happened to me and I got it diagnosed luckily for free at the dealership but then did the thing above and it hasn't come back on in over a year and a half. A lot of times they said it could be caused by a passenger having their feat under the seat where the air bag components are.
Give this a try and PLEASE PLEASE PM me if you don't get it.....don't waste your money, the unit still works.
Print this out and GO DO IT NOW!!!! It works.....mine went on in March 2004 and I was told by Nissan I needed a new passenger side SEAT airbag....the side curtain on that is INSIDE the actual seat of your car if you have it. Nissan said it was VERY common and it is faulty.....amazingly they even had some on-hand....follow this how -to!
it Works
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
Garrettz459
Sep 28, 2015 02:50 PM
