OD light blinks 16 times
Old Aug 1, 2005 | 07:01 PM
aznsap's Avatar
My OD light blinks 16 times when the key is turned to the ON position.
i tried searching, and i saw how to run the diagnostic in the FAQ's, but the thing is...
I CONVERTED TO 5 SPEED!
i also am using a 5speed ecu. somebody suggested removing the automatic transmission control unit (i tried looking in my haynes manual but i can't seem to find this)? anybody else know why my OD light is blinking or how to get rid of it?
thanks maxima.org
Old Aug 1, 2005 | 07:38 PM
aznsap's Avatar
okay, i found the location of the TCM in my FSM. is it okay just to pull this out?
Old Aug 1, 2005 | 07:50 PM
njmodi's Avatar
Do I get a tax break?
Since you don't have a transmission anymore I think you'll be ok.. you might get some CEL codes though - since the ECU might be expecting to see the TCM.. I'm just throwing out what sounds logical to me - I don't know for sure... not sure if the CEL shows any non-emissions related codes...
Old Aug 1, 2005 | 09:29 PM
aznsap's Avatar
ya, do 5speed's have TCM's?? if not then i can pull it out for sure.
Old Aug 1, 2005 | 09:48 PM
tavarish's Avatar
fwd gone rwd cr00
no, 5speeds do not have TCMs...i need to swap out my ecu as well for the swap I did last week.
Old Aug 1, 2005 | 09:58 PM
DJItalianICE's Avatar
you can probably just snip the wire off. If you pull a code, no worries, if you can check the codes yourself you'll know which ones are important or not.
Old Aug 1, 2005 | 10:13 PM
MaximaSpd85's Avatar
i have an auto, mine blinks 16 times because of the drop resistor mod, somethiing to do with shifting at full line pressure. but dont know with ur manual.
Old Aug 1, 2005 | 10:20 PM
aznsap's Avatar
ya, i'm thinking it blinks because i have the TCM in but with a manual transmission. i'll try pulling the TCM out tomorrow and seeing what happens. hopefully the light will just stop blinking.
Old Aug 1, 2005 | 10:25 PM
Maxima_Joe's Avatar
4th Gen Parts King
You could always pull the bulb since you will never use it.
Old Aug 2, 2005 | 12:39 PM
aznsap's Avatar
well i pulled the TCM today and it indeed took care of the blinking OD light problem.
Roymg
Sep 3, 2018 05:10 AM
trasmadean
Jan 20, 2018 05:05 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
yat70458
Aug 3, 2015 01:16 PM
