95 Max still got original factory brake pads
Old Aug 2, 2005 | 03:24 AM
flynlr's Avatar
yep the rear pads on my max came from the factory in 95 i did replace the fronts a year ago. now to be honest this max is only at about 40k miles now. also have original belts and sparkplugs. now the next thing i have to do is change or regrease the starter as i have the squel problem. then the ign switch takes a couple of tries before it works .but all in all since i bought this puppy new in 95 ive only had to do 1 major maint thing which is change the cv axles. oh the 40k part is just a guess as the odometer only somtimes works since 1 year ago at 33k. but till it quit i was averaging about 3k miles a year. so in conclusion. after 10 years with this max I am very pleased with the cost of ownership.
Old Aug 2, 2005 | 04:04 AM
Iron Scimitar's Avatar
Tha Snatcher
okay.........get a full tune up.
Old Aug 2, 2005 | 04:06 AM
flynlr's Avatar
why? still runs great? though i do have the 0304 and a 1008 code but still passes emissions.
Old Aug 2, 2005 | 06:42 AM
kormax97
so you rather have your car break down on you one day, rather than have a tune up to keep it well?
i guess you never went to see a dentist. "I can still chew and swallow!"
Old Aug 2, 2005 | 07:02 AM
Bobo's Avatar
You probably have the lowest mileage 4th Gen on the .org. At 59,700 miles on my 95SE, 5-speed, I know I am in the lowest mileage category.
My car has mostly highway miles on it. I still have the original front brake pads, belts and spark plugs and have no intentions of replacing them any time soon if they don't need to be changed. I only replaced the rear pads, with about 40% to the wear indicator, a few months ago as the right rear caliper was seized as a result of me not using the parking brake for about 5 years. I also still have the OEM Goodyear Eagle RSA tires on the car and don't plan on replacing them for another 5K.
Focus on replacing the fluids: transmission/transaxle (if 5-speed), power steering, brake, clutch (if 5-speed).
Have you replaced the fuel filter and air filter before?
I doubt that you need a tune-up, but should perform all the visual checks (in addition to the above) that are outlined in the maintenance schedule.
Old Aug 2, 2005 | 07:29 AM
SMX95's Avatar
HAH HAHAHAHHAHA HAHAHA
Old Aug 2, 2005 | 07:45 AM
Bobo's Avatar
I neglected to mention flushing the radiator. You should have your cooling system flushed and pressure tested if you haven't had that done in the last 2 or 3 years.
Old Aug 2, 2005 | 08:16 AM
ImmaSquashYou's Avatar
3K a year??? hymm....i do that in 3-4 weeks...
Old Aug 2, 2005 | 08:18 AM
kormax97
OT: what code did you get? give me a link to buy your maf adaptor also.
Matt93SE
May 24, 2019 02:58 PM
homeyclaus
Sep 3, 2015 06:15 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
RealityCheck
Aug 5, 2015 06:18 AM
