97-99 conversion to 3.5 liter
Old Aug 2, 2005 | 07:22 PM
gregorwise's Avatar
i was curious if anyone here has done the conversion from the 3.0 liter to the 3.5 from the newer maximas? i heard that the new engines fit the older 5 spd trannys? and you use a 2000 altima ecu. is this true cuz i am very interested in doing this project. anyone with info please reply
thanks.greg
Old Aug 2, 2005 | 07:27 PM
2 Da Max's Avatar
check the all motor form dude
Old Aug 3, 2005 | 01:11 AM
dgrun09's Avatar
stick an LS1 in that bad boy!
Old Aug 3, 2005 | 06:57 AM
NmexMAX's Avatar
dot dot dot ...
thanks.greg
Check the all motor forums to see what I mean. Yes it's been done. Yes the older 5speeds fit the 3.5L.
Most are using the stock 4th gen ECU, with, IIRC one exception, one is using the 02 ECU in his 95.
So, just out of curiousity, whre did you "hear" this?
Old Aug 3, 2005 | 07:13 AM
Loe max's Avatar
Word on the street has it that a 3.5L will drop into a 4th gen, I dont believe it, its just a rumor
Old Aug 3, 2005 | 07:34 AM
Dubbya's Avatar
VK56 Inside
It will never work.
Old Aug 3, 2005 | 07:35 AM
Kevlo911's Avatar
Kevlo for President
It only fits 95-96. 97-99 are a totally different beast.
Old Aug 3, 2005 | 07:37 AM
NmexMAX's Avatar
dot dot dot ...
Hasn't been done on 97-99 ... Besides, we all know the 95/6's are lighter
Old Aug 3, 2005 | 07:38 AM
Dubbya's Avatar
VK56 Inside
Lighter and better looking
Old Aug 3, 2005 | 10:40 AM
JClaw's Avatar
It won't work, the 3.5L is too big
Old Aug 3, 2005 | 10:42 AM
sdoherty_tjm's Avatar
put a twin turbo'd (dsm turbos) 350 in it. radiator cap blow of valves (10 psi) 650 h.p. *****.
Old Aug 3, 2005 | 10:43 AM
Nismo3112's Avatar
Custom User Title
Change to a 95-96 bumper then it will fit
JClaw's Avatar
Yeah, that's a whole lot easier than the 3.5 swap in a 97-99. Something about how the 3.5 radiator is placed, it only works with the 95-96 bumper.
Old Aug 3, 2005 | 10:44 AM
Dubbya's Avatar
VK56 Inside
I though you had to change out teh headlights as well.
Old Aug 3, 2005 | 10:45 AM
emmas97's Avatar
you guys are such d!cks lol.... mine must be a 95-96 in disguise...
JClaw's Avatar
True, but the 5th gen headlights will work, just need to cut up the 95-96 bumper a little to make them fit. The firewall issue is not that bad though, just need to move it back about 2-2 1/2 inches for the 3.5L to fit.
The real problem is getting the 350z tranny to fit, nothing a custom driveshaft well can't fix.
Old Aug 3, 2005 | 10:52 AM
Nismo3112's Avatar
Custom User Title
Build date:96?
Old Aug 3, 2005 | 10:54 AM
emmas97's Avatar
Originally Posted by Nismo3112
Build date:96?
haha more than likely but its too hot to go out and check.... mine just happens to look like a 97, but my trans is all 5th gen lol
Old Aug 3, 2005 | 10:56 AM
BigLou93SE's Avatar
Damn, you guys just tore this poor guy about 18.33 new holes...
Old Aug 3, 2005 | 10:58 AM
Dubbya's Avatar
VK56 Inside
Can we get that in carbon fiber?
And by the way.....
Old Aug 3, 2005 | 12:40 PM
chillin014's Avatar
how much is a 3.5?
Old Aug 3, 2005 | 12:43 PM
MidwestMaX1's Avatar
Just drop a V8 in there. Problem solved.
emmas97's Avatar
Originally Posted by chillin014
how much is a 3.5?
if you want one pre-built, call tilleys99 at his shop 717.867.0381, or if you just need info
Old Aug 3, 2005 | 12:46 PM
NmexMAX's Avatar
dot dot dot ...
how much is a 3.5?
www.car-part.com
700
Not only is it too big, it's too heavy for the front 4th gen suspension
deezo's Avatar
Changing out the firewall makes it easier.
Old Aug 3, 2005 | 01:06 PM
chillin014's Avatar
www.car-part.com
700
the 3.5l from newer maxima's is too big for my 95? what if i get coilovers for tokicko/hr's?
and if i could get the motor for 700 dollars, that would be awesome...the only thing is, how can you tell the condition of a motor.
Old Aug 3, 2005 | 01:26 PM
NmexMAX's Avatar
dot dot dot ...
You need to do metallography on the cyilnder walls...
Spend 12 minutes in the All Motor Forum reading about the 3.0 and 3.5L, and swaps etc. . then come back here ...
Old Aug 3, 2005 | 01:43 PM
MDeezy's Avatar
I swar if anything happens to my current engine, I'll have no choice but to put the VQ35 in. Only problem is I take such good care of my current one.
Old Aug 3, 2005 | 01:45 PM
NmexMAX's Avatar
dot dot dot ...
Drain the oil & coolant, put a brick on the accelrator, leave it in neutral, go watch the news, and come back ...
Old Aug 3, 2005 | 01:47 PM
Dubbya's Avatar
VK56 Inside
Go with the coil overs. I hear they have a stiffer rebound and should support the engine weight better.
Old Aug 3, 2005 | 01:48 PM
MDeezy's Avatar
I wish it were that easy.
Old Aug 3, 2005 | 01:50 PM
chillin014's Avatar
Sorry, yeah ill go read there. I thought this was one of those things I'd never tamper with until I read this thread so I JUST NOW became interested.
My bad
And I hear ya mdeezy
Old Aug 9, 2005 | 10:54 PM
BRUNOJLB's Avatar
Great job on the car, where'd you get those amazing headlights? jlb44@bu.edu
Old Aug 10, 2005 | 03:12 PM
laylow1988's Avatar
ok so i went out and bought a 95 bumper for the 3.5 install on my 97 and put all 4 windows down so i can have more room to work with. i will get the altima ecu this week and the honda accord wire harness too. how much super glue do i need for the install? someone said 3oz will do.
Old Aug 10, 2005 | 04:42 PM
MDeezy's Avatar
No the 3oz wont due, You'll need atleast the 9oz bottle. You'll need the final drive from the 2003 auto tranny. The shimms from a 96 tranny. The Injectors from the Pular, along with the exhaust hanger from a 01 stanza
Fbana41
Aug 29, 2016 12:18 PM
Calabar
Oct 5, 2015 09:57 PM
09maxshawn11
Sep 30, 2015 10:28 AM
kjlouis
Sep 14, 2015 11:22 AM
Hdnseek
Sep 9, 2015 05:55 AM
