Rattling on engine
Old Aug 8, 2005 | 11:15 AM
Dexter's Avatar
Rattling on engine
I noticed my engine giving off a loud rattle since last night, it sounds like it's coming from the alternator belt and the vibration can be felt over the plastic facia and the manifold (pipes on top of the facia). Do you guys think the belts are worn and need to be replaced (my guess) of am I running on a broken valve (say it isn't so!)
-Dexter
Old Aug 8, 2005 | 01:45 PM
MaximaInCT203's Avatar
schemes on chicks in his max.
sounds like the timing chain- visit the Sticky on this forum under 4th gens
Old Aug 8, 2005 | 03:17 PM
maximaking's Avatar
You may want to check your belt tensioner
Old Aug 8, 2005 | 03:28 PM
Dexter's Avatar
wtf?! i thought that thing never needed to be changed.
-Dexter
Old Aug 8, 2005 | 03:29 PM
Dexter's Avatar
is there info on that on the stickies or do I need to check with HAYNES or CHILTON (i have both cuz i figured one would have something the other wouldn't)?
-Dexter
Old Aug 8, 2005 | 03:35 PM
no the timing chain would never need to be adjusted- never said it wouldnt need to be replaced someday
Old Aug 8, 2005 | 04:06 PM
maximaking's Avatar
While timing chain failure is pretty rare, the timing chain tensioner does go bad from time to time. I always like to check the cheapest preblem 1st. This is why I recomended the belt tensioner assymbly. I thought my chain tensioner was bad but the guys at the NIssan dealer looked at it and told me to replace the tensioner and even told me how to do it. Also if you've recently done any alternator work check to make sure the alternator is secured. I've seen that one cause rattles too.
Todd
TOdd
Old Aug 8, 2005 | 04:07 PM
king hit it on the head....
Old Aug 8, 2005 | 05:24 PM
Dexter's Avatar
Todd
TOdd
yeah I had the alternator replaced but that was over 6 months ago, and the rattle just now started to act up.
-Dexter
Old Aug 8, 2005 | 05:31 PM
Dexter's Avatar
Todd
TOdd
you must enjoy some pretty nice dealerships in KY but here in NAPTOWN taking a car to a mechanic/dealership is a Nightmare.
-Dexter
Old Aug 8, 2005 | 06:17 PM
maximaking's Avatar
Yah it's a little small nissan dealer. Anyhow I had PepBoys do an alternator install and I later founr out that the alternator was getting ready to fall off. they didn't bolt it back up properly. It was making a noise. Follow the path of the drive belts. Find the Belt tensioner. CAREFULLY use some sort of a listening device and check the belt tensioner, alternator and other parts. Once you locate the location you are one step closer to the cause.
Old Aug 9, 2005 | 12:29 PM
Dexter's Avatar
I place the key to fell vibrations, my theory is that the problem must come from where the vibration is strongest. I'm starting to belive it is the tensioner belt Where can I buy a GOOD tensioner belt assembly AutoZone? NAPA? etc.
-Dexter
Old Aug 9, 2005 | 12:42 PM
Dexter's Avatar
the link is broken
-Dexter
Old Aug 9, 2005 | 12:56 PM
Dexter's Avatar
Appointment Made
The MAX is scheduled for surgurey this friday, I'm pretty sure it's the tensioner the sticky helped a little bit and I'm doing research on it in the Service Manuals. I'll keep you updated if I need any help along the way.
-Dexter
Socalstillen
Sep 20, 2015 11:46 PM
lrb6805
Sep 17, 2015 04:49 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
thenewguyy
Sep 12, 2015 11:12 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
