Starter replacement part 1
Old Aug 11, 2005 | 10:11 AM
wahoohead's Avatar
I read just about every starter thread and found them all helpful to a certain degree, however I think I can add a bit. The overall procedure is simple. Take out the battery and all the air intake tubing, boxes, filter,snorkles etc. Disconnect the battery to the starter lead (one nut) and disconnect the thin lead from the connector.
This will allow you to see the starter and with the removal or pushing out of the way (various wiring harnesses) you will be able to see the two bolts that hold the starter to the engine.
The short bolt is a 14 mm bolt. Mine came out very easily and I figured I was set. The next bolt is a 17 mm. I started with a 3/8 " drive it would not budge. I moved up to a 1/2" drive with a 17 mm impact socket. It would not budge. I tried spraying PB on the bolt, I tried banging on the bolt and more PB (liquid wrench stuff). Finally with an additional 12" pipe as a breaker bar on the 1/2" rachet it broke free. That bolt is really in there. I would guess at better than 50 ft/lb (?) of torque. Anyhow it is a lot, and it will take a lot of puling even with an extension.
Don't bother with PB or any other such product, the threads that you would like to reach are 4-5" from where you can spray.
Just get a 1/2 rachet and a 1/2 drive 17mm and a breaker bar and it will come loose.
I for some reason have a problem getting electrical push together connectors apart. It took ten minutes to get the thin wire connector apart. I have no real understanding of what I did to get it apart but I think it just needs to get wiggled apart. I could find no catch.
This is part 1 as my starter has not arrived.
Old Aug 11, 2005 | 10:52 AM
MIXXMAX's Avatar
The short bolt is a 14 mm bolt. Mine cam out very easily and I figured I was set. The next bolt is a 17 mm. I started with a 3/8 " drive it would not budge. I moved up to a 1/2" drive with a 17 mm impact socket. It would not budge. I tried spraying PB on the bolt, I tried banging on the bolt and more PB (liquid wrench stuff). Finally with an additional 12" pipe as a breaker bar on the 1/2" rachet it broke free.
Don't bother with PB or any other such product, the thread that you would like to reach are 4-5" from where you can spray.
I agree with your procedure...but you can still get to the starter without taking out your battery. Just disconnect the ground and you still have more than enough room.
Old Aug 11, 2005 | 10:57 AM
wahoohead's Avatar
Battery was shot
I had to replace the battery anyways so it was already out. I agree you will problably have enough room with the battery in but more room is more better.
Old Aug 11, 2005 | 11:05 AM
sdoherty_tjm's Avatar
add it to the stickies
Old Aug 11, 2005 | 11:10 AM
MJaeger's Avatar
http://www.motorvate.ca/mvp.php/516
And yes that one bolt is REALLY ON THERE!
Old Apr 5, 2010 | 01:11 AM
wcasskicker's Avatar
This is where I'm stuck too. The 17mm bolt, I'm getting a break bar tomorrow so I can put on my new starter. Thanks for the tip.
Old Apr 5, 2010 | 09:11 AM
M in KC's Avatar
The breaker bar ought to get you home on that bolt.
CRizz
41
Jun 7, 2021 05:42 AM
vingodine
45
May 21, 2016 12:46 PM
Samedi
Aug 13, 2015 04:05 PM
kirkhilles
Aug 8, 2015 10:53 AM
