Mevi question.
Old Aug 17, 2005 | 10:18 AM
SMX95's Avatar
Mevi question.
I just wired up that bad boy (may I add at 5-7k it sounds like a monster) The harlan switch i have the LED doesn't work. I wired up an led to my dash (Next to my dimmer switch). The switch says mevi and it has a green light. I tested the light on the battery and it worked. I sodderd it to the LED on the switch and it doesn't light up. Is there anyway I can activate that light? I put power and ground to the led on the switch. DO I just put power to the long led of the led on the switch and ground the other to the battery? Or can I ground it to the battery and the other one power to the TACH wire?
Old Aug 17, 2005 | 10:20 AM
sdoherty_tjm's Avatar
how much did it cost you?
Old Aug 17, 2005 | 10:24 AM
SMX95's Avatar
what did? I bought the whole mevi for 450 everything with it. I polished the manifold and kept it on for 4 months. Yesterday at school, I decided to finish the rest. So I did it with another friend of mine. Im just wondering where else can i tap that light.
Old Aug 17, 2005 | 10:40 AM
450, i thought that it would cost more than that for everything. i dont have one, so i cant really help.
Old Aug 17, 2005 | 12:04 PM
NmexMAX's Avatar
dot dot dot ...
IMO .. Harlan is
But it has worked flawlessly for Stehpen Max and Dave B .. but for the res of us, it really sucks.
I'm sorry, but you're a in my book if you have the MEVI on for 4 mos before wiring it .... Did you at least have a JWT ECU to go with it during it's non/vi'd timeframe?
Also, sounds like you may not have it wired correctly if it's not lighting up .. might mean you're RPM signal isn;t reaching where it should be.
Do you have it set to coil/cyl? Not V6 .. as it needs to read coil packs.
Are you using the wire from the coil?
Old Aug 17, 2005 | 01:15 PM
Nismo's Avatar
Make shure the LED has the correct resistors soldered on or you will blow it. If I remember correctly, I wired the + of the LED to the signal on the harlan and grounded the other to the chassis.
Old Aug 17, 2005 | 04:02 PM
RA030726's Avatar
I'm nutty for Nissans
also polarity matters, since it is a diode, but im sure you know this.
Old Aug 17, 2005 | 04:08 PM
1FSTMAX's Avatar
you need to use the RPM switch to ground the light.. and it should light up. That's how i had it hooked up.
Old Aug 17, 2005 | 08:32 PM
SMX95's Avatar
Originally Posted by NmexMAX
IMO .. Harlan is
Yeah, thanks for the comments... I didn't want to do the hardware. The time I installed the manifold it was still very cold out. I never wanted to take my time with it just do to the fact I hate electronic wiring. I decided to toughen up and do it. So I did. The whole mevi kit I bought it from someone. They had no problem with the switch neither do I. It opens all the time, and sure puts a smile on my face. This was a simple question on how to wire up the led light. The led in my dash already has a resistor, the led on the switch doesn't work when mevi kicks in.
Old Aug 17, 2005 | 09:47 PM
Flava_24/7's Avatar
Boosted Panda
7k with no ecu upgrade???
Old Aug 18, 2005 | 05:28 AM
sean05's Avatar
ahh lol mine is sitting in the box right by my feet and i cant find the damn gasket between the manifold and manifold cover. idk what to do!!!
Old Aug 18, 2005 | 06:03 AM
deezo's Avatar
I'm sorry, but you're a in my book if you have the MEVI on for 4 mos before wiring it .... ?
I had mine in my closet for almost 2 years.
Old Aug 18, 2005 | 06:27 AM
NmexMAX's Avatar
dot dot dot ...
Mine sat in my back seat for 6 weeks
Old Aug 18, 2005 | 07:13 AM
SMX95's Avatar
Now the mevi doesn't want to work. I have the instructions for the harlan switch. Everyone said if the LED doesn't light up theres a problem. My mevi worked opened at 5100 without the light working. Now I tried to reset the thing and it doesn't light up and now it doesn't even work. So can anyone help me out here....
Old Aug 18, 2005 | 07:24 AM
NmexMAX's Avatar
dot dot dot ...
It will be hard to reset it w/o the LED working ... Your harlan just did what many others on here exp[erienced ... wigs out sometimes .. have to reset it .
Old Aug 18, 2005 | 08:31 AM
SMX95's Avatar
this blows! Does the summit one wire up the same way as the harlan because if it does ill buy a summit one. Oh can I reset the thing If I cant see the led light up?
Old Aug 18, 2005 | 08:36 AM
NmexMAX's Avatar
dot dot dot ...
It wires the same with the exception of the tach signal wire from the ECU rather than the coil wire.
My Summit has not "wigged out" in the 2 years I've had it. And the red LED is always on when powered, and the Green turns on when activated.
Old Aug 18, 2005 | 08:39 AM
SMX95's Avatar
question is how can i re-activate it without the light being on. It was working fine intill i decided to touch it.
Old Aug 18, 2005 | 08:57 AM
NmexMAX's Avatar
dot dot dot ...
That's not the question you asked me ... so I cannot halpe you
Old Aug 18, 2005 | 09:20 AM
SMX95's Avatar
bump, anyone tell me how to get this **** to work? Where can I buy another harlan switch it seems his business didn't do so well.
Old Aug 18, 2005 | 09:33 AM
NmexMAX's Avatar
dot dot dot ...
Why not buy a Summit :
Old Aug 18, 2005 | 09:34 AM
SMX95's Avatar
because your very knowledgable. My mevi worked but yet I wired something up wrong... It could have just been a blown led?? dont you think. Anyway sure why not spend $50 bucks to buy a switch..
Old Aug 18, 2005 | 09:43 AM
NmexMAX's Avatar
dot dot dot ...
Well, you asked where to get another harlan switch ...
common sense should tell you, if his buisness isn't doing so well, why not go somehwere else. If it wigged out once, odds are you will have the problems that a lot of other members have had ... it will do it again and again and frustrate the holy hell out of you.
I went through 2 harlans (100$) before I got smart ...
I tried helping you ....
deezo's Avatar
Fark that Harlan. Buy the Summit and be done with it. I recommend hooking the Summit to the TAM screw on the back of your guage cluster.
Old Aug 18, 2005 | 02:23 PM
SMX95's Avatar
With the summit one Everything plugs in as the harlan did. I have a relay on my harlan one. My tach is wired to the TAM screw then I have another set of wires going to the solenoid one from the relay to the solenoid and another one to ground. The other one is going to battery power. Everything worked just fine the 1st time I hooked it up.
Old Aug 18, 2005 | 02:29 PM
NmexMAX's Avatar
dot dot dot ...
Could've told you tht since I'e had both.
What's your point?
Get a SUMMIT .... Get on w/ life.
Seeing as the results with other memebers, there seemed to be a trend, and it would seem to screw up the electrinics within the board to the point where it would not work anymore.
With that said, your board has 2 things wronmg with it.
1.) It wigged out once, so that is just a sign that it will continue.
2.) Your LED is out, meaninf it only needs a new LED or, the switch has more complex problems.
I've had mine(Harlan) wired many different ways, exaclty like yours, w/o a relay, w/ a relay to the coil etc etc ... My conclusion came after my 2nd Harlan died, I;m trying to tell you this so that you don;t go a day you don;t have to w/o a functioning VI, as well as save you money from buying another Harlan ...
Old Aug 18, 2005 | 02:35 PM
SMX95's Avatar
Im not asking that, Read what I said. Will the summit SWITCH hook up just like the HARLAN switch does. Im lookin at the paper and from what I understand:
-Red wire- +12 volt (battery)
-Black (Ground)
-White (TACH)
-Grey it says it provides ground for a circuit and will open upon reaching the selected RPM limit. Does that go to ground as well?
-Yellow is normally open and provides ground for a circuit and will open upon reaching the selected RPM limit
So what do I do with the yellow and Grey wire?
Old Aug 18, 2005 | 02:48 PM
NmexMAX's Avatar
dot dot dot ...
-Black (Ground)
-White (TACH)
Leave the grey alone, use the yellow.
Old Aug 18, 2005 | 03:16 PM
sean05's Avatar
where is the TAC screw for the summit switch? Also i have the AC Delco solenoid and how do you connect the wires to it with the weird connection points?
Old Aug 18, 2005 | 06:57 PM
SMX95's Avatar
The yellow wire I just run it to ground?
Old Aug 18, 2005 | 09:52 PM
HomerMAC's Avatar
Donating i30 Owner
... wow i love the sarcasim.. hehehehe... SMX gets pissd off easy... so who want sto sell me thier mevi.. = ) if its just sitting there.. hehehe.. = )
litch
123
Jan 4, 2024 07:01 PM
BkGreen97
Apr 2, 2016 05:47 AM
doctorpullit
Mar 29, 2016 11:08 AM
lrb6805
Sep 30, 2015 08:12 AM
pears
Sep 18, 2015 05:25 AM
