MEVI Install Problems
Old Aug 18, 2005 | 02:04 PM
sean05's Avatar
i got the MEVI on and all the lines connected. We went to start the car and it wont start. It fires but then lets off a big PSSST. ANyone had this problem before?
Old Aug 18, 2005 | 02:19 PM
SMX95's Avatar
Did you hook everything back up? Did you forget about the 2 coolant lines by the EGR? Did you plug back in you IAC? Did you replace any gaskets? Check your TPS, MAF and IAT (Intake air temp) sensors. Make sure the hose for the IAC to the intake is tight and sealed. Did you work on the engine when it was cold or hot? You have have wrapped the intake since its aluminum. but I highly doubt that. Did you hook up the hardware for the mevi to open as well? Checked where you tapped your VAC (T) make sure its all good. It seems everyone is having mevi problems.
Old Aug 18, 2005 | 04:39 PM
sean05's Avatar
FIXED!! woo wow its nice to hear the car run. Got the mevi partly running. The vacuum always suckin and the butterflys are always open. Im not sure why this is but i havent connect the summit switch or the relay. I need to get the connector for my AC Delco (GM) solenoid. It has a weird connector that didnt come with the kit. Im gonna try napa to see if they have it. If not im gonna have to go 2 the GM stealership. Tomarrow in going to install the summit swith if i can find the connector for the solenoid. When i get the summit switch wired where is it TAC thing i have to connect it to? It is by the passangers left foot in there. I saw in the FAQs that it was a green and white wire.
Anyways, the mevi pulls extremely nicely up high. It has a different sound now with the MEVI on. Cant wait to get it fully working!
Old Aug 18, 2005 | 06:57 PM
SMX95's Avatar
Yea Everyone in my school shop heard my mevi kick in and ran to the car and were like wow that **** really screamed. Now I got to order a new switch
Old Aug 18, 2005 | 09:32 PM
sean05's Avatar
idk whats wrong with mine. WHen i start the car the actuator pulls and opens the vi. Even though i dont have it wired up should it be activated or do i hve something backwards? Also waht solenoid are you using? Im using the GM and cant find a way to connect wires to it. confusing stuff
Old Aug 19, 2005 | 04:38 AM
SMX95's Avatar
are you using a relay with your kit? My kit came with a relay
Old Aug 19, 2005 | 05:00 AM
deezo's Avatar
The VI is great. After I had my KS replaced, my car hauls.
Old Aug 19, 2005 | 05:22 AM
sean05's Avatar
ya i have a relay but havent installed it yet. I couldnt find a way to wire up the GM solenoid because it have a weird connector.
Old Aug 19, 2005 | 05:42 AM
sean05's Avatar
grr im about to beat this thing. No matter what way i set up the vacuum lines the actuator opens when i start the car. I cant figure out why. Does anyone have pictures of there vacuum lines so i can get a better idea?
Old Aug 19, 2005 | 05:56 AM
sean05's Avatar
is the fuel pressure regulator the little white circular thing? Can someone post a pic of a close up of the FPR then the vacuum lines and how they go. I have it exactly how it is in this pic:
Im not so sure that i have the T fitting correct by the FPR, thats my only concern. But the damn actuator wont close. Its always open. But i still havent wired anything because i dont have the proper connector for the GM Solenoid.
The GM solenoid is slightly different then what it looks like in hte pictures but i have it hooked up similarly
Old Aug 19, 2005 | 06:16 AM
laylow1988's Avatar
the actuator is probably constanty pulled cause you have it connected to a vacuum line directly and not threw the solenoid that activates when the actuator is pulled by the signal that the rpm switch sends to the solenoid when you reach the set rpm on the rpm switch.
with the stuff you have you don't need a relay.
1.summit racing rpm switch
2.ac delco solenoid
3.hoses
4.thats it nooo relay!!!
now for the solenoid i have yet to find the clip that goes to it so what i did was go to pep boys and look in the ile and look for these little metal clip things i don't know the name of it yet i will have to go there when im at my other job and post a pic of it for ya and the name of it. matter of fact i have a few extras at home so if you pm me your address i can mail you the two that you need already set up with the positive and negative wire attached to it for free!! and all you have to do when you get it is get a needle nose plier and squeeze them on the neg and pos nubs thats on the solenoid. once you squeeze one on give it alittle tug if its snug leave it alone if it looks like its about to come off squeeze it with the pliers till its snug. then do the other side the same way then connect the two wire to there connections which is the positive to the positive of the battery terminal and the negative wire to the rpm switches yellow wire or grey they both worked for me but to be positive let me get back to you on that.
the tach signal i used the screw behind the rpm guage i will take mines apart and snap a pic of the screw and post pic. dont mess with your ecu wire man.
Old Aug 19, 2005 | 07:37 AM
sean05's Avatar
woo finally some help! i would greatly greatly appreciate you taking some pictures. ill PM you with my address. Thanks so much again. The reason i think the accuator is staying open is bc the solenoid has to have current to release air through the vent hole. I read this in another thread somewhere. But THANKS AGAIN!
Sean
Old Aug 19, 2005 | 10:02 AM
laylow1988's Avatar
here is acouple links that helped me when i was first doing my mevi install
http://forums.maxima.org/showthread.php?t=335310
http://forums.maxima.org/showthread.php?t=217001
http://forums.maxima.org/showthread.php?t=347286
http://www.cyberhub.net/manifold/
Old Aug 20, 2005 | 08:53 AM
laylow1988's Avatar
sean i will send you those wires today in the mail. good luck with the install
Lakersallday24
Nov 7, 2024 07:31 PM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
Cotozic
Jun 28, 2017 08:01 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
kirkhilles
Aug 8, 2015 10:53 AM
