changed brake rotors / pads .. now vibrations
Old Aug 18, 2005 | 02:19 PM
nadir_s's Avatar
vicodin ... gift of life
Hi guys,
I changed my brake pads and rotors last weekend. At about 70-80mph, i start noticing a vibration.
I didn't have this before so I really can't say it's unbalanced tires.
Any suggestions? I made sure the wheels were torqued to 80lb.
I've also noticed the e-brake, when pulling it up, is a bit loose or doesn't require as much force as it used to before.
Old Aug 18, 2005 | 02:23 PM
njmodi's Avatar
Do I get a tax break?
What rotors did you use?
What pads did you use?
Did you clean/regrease the caliper pins?
Did you do the front or rear brakes (or both)?
Old Aug 18, 2005 | 03:54 PM
dr-rjp's Avatar
Originally Posted by nadir_s
Hi guys,
Did you replace all four pads & rotors?
Old Aug 18, 2005 | 06:57 PM
nadir_s's Avatar
I replaced all the pads and rotors.
I used OEM pads with brembo slotted rotors.
I didn't clean / regrease the pins actually, they were moving pretty freely. You think that could be an issue?
Old Aug 18, 2005 | 07:10 PM
njmodi's Avatar
1. Perhaps you didn't seat the pads fully against the rotors, they might be binding in the pad retaining clips.
2. The caliper's might also be sticking slightly (since you didn't clean/regrease the pins) - and it might be more noticable because of the thicker pads.
3. You might have just gotten a rotor that has bad runout right out of the box. Thats why I asked which brand - this is more common with the cheaper ones. This is unlikely since you used Brembo's - but possible.
I know its annoying, but you could swap in your old rotors (if you still have them) and see what happens.
Cheers.
Old Aug 19, 2005 | 06:56 AM
dr-rjp's Avatar
Ditto on a potential caliper problem. I had to have mine replaced recently in the rear after hearing and feeling vibrations I thought were due to worn out pads.
Also possible is if you made any quick "panic stops" with the new brakes before the pads and rotors had a chance to bed.
Old Aug 22, 2005 | 08:42 PM
nadir_s's Avatar
ah ic hmm. .. i've also noticed that when i get out of the car after a 20-30 min drive, the smell of brakes .. perhaps the pins are sticking or something.
Old Aug 23, 2005 | 05:00 AM
njmodi's Avatar
Sounds like the pins are sticking... did you make sure your parking brake cable is not binding?
BkGreen97
Apr 2, 2016 05:47 AM
bbsitum
Sep 11, 2015 04:55 PM
beerman1378
Sep 8, 2015 02:19 PM
crazyespn
Sep 3, 2015 01:30 PM
A32goldylocks
Sep 2, 2015 06:39 AM
