running wires
Old Aug 23, 2005 | 01:13 PM
9maxse5's Avatar
running wires
I need to run a power wire from my sub..where is the easiest spot to go thru the firewall? is there a place that is easy to get to? help please
Old Aug 23, 2005 | 01:21 PM
NY 95 VQ30DE's Avatar
just pick a spot below the master cylinder....make sure you check both sides of the firewall so that you dont drill through wires on the other side....and get on with it. If you do it there you can easily run the wire under the door sills on the drivers side.
Im sure you already know to use a grommett in the hole, so your wire doesnt get eaten alive. And to run your rca cables on the OPPOSITE side from the power wire.
wyobbagy
Jan 3, 2023 12:03 PM
The Frye
Sep 2, 2021 11:03 AM
9aj9
Apr 5, 2020 12:11 AM
captchaos
Mar 15, 2016 12:18 PM
ballerchris510
Sep 10, 2015 09:35 PM
