OBDII Scanner
Old Aug 23, 2005 | 02:01 PM
sky jumper
OBDII Scanner
I'd rather buy an OBDII scanner than do the screwdriver self diag thing. anyone got advice on models, features, etc. that I should look for? Ideally I'd like to spend about $100 bucks.
could/will a '99 throw codes if the CEL is not on? (e.g. for the KS)?
Old Aug 23, 2005 | 02:18 PM
njmodi's Avatar
Do I get a tax break?
PepBoys routinely sells Actron scanners for < 100 bucks...
Yes - you may see the 0304 (KS) code without the CEL in a 99.
Old Aug 23, 2005 | 02:21 PM
MIXXMAX's Avatar
Actron's are good scanners. I have the Actron CP9135 model. It reads all the "P0" codes with some "P1" codes. When I bought mine, it was like $99.00 at Pep Boys. The more expensive models reads more "P1" codes like I have in my 5th gener. But, 4th gener's don't have as many "P1" codes as the 5th gener's, so this scanner will work for you.
Old Aug 23, 2005 | 02:23 PM
Jeff92se's Avatar
I'm needing a caw
This should keep you busy
http://forums.maxima.org/showthread.php?t=332205
Old Aug 23, 2005 | 02:26 PM
sky jumper
cool. thanks guys.
Old Aug 23, 2005 | 05:49 PM
robsst's Avatar
I also saw an OBDII at Walmart for $100.
Old Aug 24, 2005 | 05:47 AM
mbb6's Avatar
can this also reset the ecu
or do i have to do the screw thing to reset it?? it has an erase code option, but i am not sure if it just erases and resets or just erases.
Old Aug 24, 2005 | 05:50 AM
njmodi's Avatar
The scanners can read codes and reset the ECU/clear the codes.
mvm062
Nov 30, 2020 09:00 AM
lummyrob
Sep 2, 2015 12:31 AM
My 4DSC
Jun 9, 2001 10:02 AM
My 4DSC
Jun 8, 2001 04:56 PM
