seems at least 80% of us have this bog, hesitation problem
Old Aug 24, 2005 | 09:57 AM
THEJEFFERATOR's Avatar
the mystery bog, hesitation stuttering problem is driving me insane, i've tested and pulled on and wiggled wires and replaced parts and thought and read and on and on for two friggin months now.
last night i spent an another hour wasting my time and the damn car kept on stalling. at least 17 times, sometimes every min., sometimes after 5 min. sometimes it would start right back up like nothing happened, other times it was laoded up and ran like ****. sounded like a boat !!!
i know alot of you have heard this from me before and i appreciate all the help and response, but somebodys got to figure this out !!!
i know there are alot of people with the same symptoms, but what about the stalling? seems electrical or sensor related but everthing seems to check out, still no codes. it just shuts down!!! has anybody tried a new or reprogramed pcm and had any luck???
Old Aug 24, 2005 | 10:14 AM
With all the time, energy, and research you've spent.... and not figured it out, maybe it's time you brought it to a professional mechanic?
Old Aug 24, 2005 | 10:39 AM
Majestic's Avatar
Yahhhhhhh
Better to spend money for it to be diagnosed than waste you time when you might be looking in the wrong areas.
Old Aug 24, 2005 | 11:35 AM
i wish i could afford to go that route, but unfortunatly i can't right now..i'm gonna have to stick it out a little longer or just sell it.
Old Aug 24, 2005 | 11:50 AM
Bobo's Avatar
It might nly cost a $100 or $200 or whatever to get it diagnosed and fixed. It could be something as simple as a vacuum leak. I would hate to see a 95SE be flogged just because the owner is having a tantrum, lol!
Old Aug 24, 2005 | 01:22 PM
NmexMAX's Avatar
dot dot dot ...
Never ...
I don't care how long it takes me, I have no faith in mecahnics and their knowledge to Maximas ... If you spent that long and that many times phukking with it ... myabe it was time to walk away and take a break ... A fresh mind is > than a tired/confused/frustated one.
a 1-200$ tantrum ..
Old Aug 24, 2005 | 01:26 PM
MDeezy's Avatar
what have you checked with the car?
If there is a org member in your area with diagnostic tool of their own, like on a laptop so you can monitor varous signals, this can help.
Have you done a vacuum test?
Old Aug 25, 2005 | 02:06 PM
i've checked most of the harness, maf, egr,ks,plugs,coils,fuel flt,iacv,tps, etc. tryin the cts tommorow cuz its cheap, but after that ? recheck coils ? ecm ? i have a code scanner, nothing
i may have access to a snap-on diag. scanner this weekend.
vac test? besides spraying carb cleaner all around at diff. temps and rpms, i haven't checked yet for internal leaks.
thanx
Old Aug 25, 2005 | 02:12 PM
Another alternative is to dish out $75 to have your problem diagnosed by a trustworthy mechanic, then fix it yourself and save a bunch of money. Between paying $75 and then fixing the car, or di<king around with a car trying to figure it out for months on end, I'd pay the money and get the problem solved so I could start enjoying the car again.... Just a thought.
Old Aug 25, 2005 | 06:31 PM
nismos14's Avatar
§è~® f®ÈÄk
Did you clean the TB and IACV? Try running seafoam?
Old Aug 25, 2005 | 07:51 PM
JoeB
I would definetly do a vacuum test. Would'nt hurt to check your fuel pressure also.
Old Aug 25, 2005 | 07:53 PM
maxinthamax's Avatar
man mechanics are a waste. specially the stealdealerships
Old Aug 25, 2005 | 08:34 PM
JeEvE's Avatar
Did you check your grounds? Its easy to clean them off and it cant hurt. When I did my motor swap, I had a bad ground off the main wiring harness and it was for the o2 sensors, cam/crank sensors and a few other things. The bad ground would cause the car to stall out once it hit operating temp, after running another ground wire, it ran perfect.
Old Aug 25, 2005 | 08:52 PM
Armelius's Avatar
The amount of money you would waste on a master/novice mechanic you could buy some serious tools to help you diagnose your problem. Do all the compression, vacuum and fuel pressure tests and then work towards testing the coil packs. Eventually you will find it if it isn't intake or sensor related you will eventually figure it out.
Old Aug 30, 2005 | 03:32 PM
did the temp sens. cleaned iacv and tps. checked all grounds...nothing
not getting any reading from any of the coils ? m.meter only goes to 2k ohms, is that high enough for coils?
stopped by a shop today, guy said to check the dist. cap .....idiot !!!!!
Old Aug 30, 2005 | 03:35 PM
Jatan's Avatar
Old Aug 30, 2005 | 03:44 PM
Originally Posted by JaTaN
Been fishin through the buletins, im gonna really tear into the harness. i saw the one about the ecm countermeasure/ replacement ecm. my build date is 4/04. probably one of the first 95's out there !!! could the ecm be shot or just never upgraded?
Old Aug 30, 2005 | 03:46 PM
NmexMAX's Avatar
dot dot dot ...
You have the newest 4th gen out there.. And IMO, the best looking 04/05
Old Aug 30, 2005 | 03:59 PM
yeah, it's been a long day...04/94 !!!!!
somebody get me a beer ...please !!!!!!!!!!!!
Old Aug 30, 2005 | 08:11 PM
Stuntin' 101's Avatar
how do u know your coil packs are good?
Old Aug 30, 2005 | 09:43 PM
blackmaxx96's Avatar
There's never a day when something's not on sale
I say take it to Nissan.
And look in the bay, and see who has a ASE master mechanic certification, and ask for him to do the diagnostic on your car.
It costs $75.00, and if after weeks of troubleshooting nothing has been solved... its definately worth while.
Old Aug 30, 2005 | 09:54 PM
s0ber's Avatar
check engine coolant temp sensor
Old Aug 31, 2005 | 09:00 AM
just replaced that saturday....no difference
Old Aug 31, 2005 | 09:03 AM
im not sure, thats part of the prob. no reading on the multimeter on any of them??? strange
Old Aug 31, 2005 | 09:07 AM
[QUOTE=blackmaxx96]I say take it to Nissan.
i guess im gonna take it tommorow.
Old Aug 31, 2005 | 09:30 AM
Pappa Grande's Avatar
Do you have a "broken" CEL screw? My screw on my 95 was broken. By this I mean when I went to check or reset a CEL the screw would keep turning. I would have to be very careful when resetting a CEL, specifically how many times I turned the screw and the position of the screw when I was done. If I did so incorrectly, the car would stall.
Old Aug 31, 2005 | 09:37 AM
NmexMAX's Avatar
dot dot dot ...
I don;t think that has ever been figured out, the whole ... turning the screw relation to idle .. My idle is set @ 8-900 RPM as per the screw ...
Old Aug 31, 2005 | 09:46 AM
i've never touched the screw, fortunatly i have access to a scanner. but i could check it. i'm thinkin if the screw was " off " it would run bad all the time. last night i tried to get it to act up and it wouln't, in fact it ran perfect. had her goin a buck 20 on the parkway, never missed a beat. this morning, it stalled and sputtered the whole 5 miles to work !!!!!
Old Aug 31, 2005 | 10:04 AM
nismomax98's Avatar
u check the "PCV " valve mine was dirty and it fixed the bog u mentioned give it a shot
Old Aug 31, 2005 | 10:12 AM
97Maximus's Avatar
Shift_custom
i agree try cleaing your throttle body.. just get some carburator cleaner or throttle body cleaner from your local parts store.. and clean your throttle body.. then do some seafoam through the tank and in the intake manifold.. i did this and it cleared everything up on mine.. just a suggestion if you havent already tried that.. good luck
Old Aug 31, 2005 | 10:21 AM
Loe max's Avatar
maf?
10char
Old Aug 31, 2005 | 11:37 AM
did all that, twice, no luck.
Old Aug 31, 2005 | 11:43 AM
[QUOTE=Loe max]maf? maf voltage seems ok, cleaned the screen and checked wires. might try to find a used one to be sure.
funny, i almost bought a A90, but it need too much...maf, struts, brakes, etc.
Old Aug 31, 2005 | 02:21 PM
justinbryner's Avatar
When I pulled my pcv valve out, it was almost completely blocked off. A new one seemed to fix the bog, and improved gas mileage too.
Old Aug 31, 2005 | 02:32 PM
Shift_max power's Avatar
my maxima hesitates 2
Old Aug 31, 2005 | 03:18 PM
mine was clogged, changed it and it only idled better
Old Aug 31, 2005 | 03:31 PM
one question.. what is it like when you first start in it the morning..when the engine is cool... does it do all of this, or does it only do when the engine is warm
Old Aug 31, 2005 | 03:39 PM
about 50/50 sometimes cold, sometimes hot, sometimes just idling, sometimes at 45 mph. never the same scenerio.
Old Aug 31, 2005 | 06:30 PM
if it only does it when the engine is warm.. i would suggest one or more bad coil packs.. if it does it AS SOON AS you start the car when its cold.. its not them
Old Aug 31, 2005 | 07:23 PM
nismos14's Avatar
§è~® f®ÈÄk
Did you just decide not to read his post? lol He said sometimes hot, sometimes cold sometimes idling sometimes at 45 mph
