resetting ecu
Old Aug 24, 2005 | 02:29 PM
domlcardio's Avatar
resetting ecu
i read the part on resetting ecu and it talked about a screw you need to turn. but when i took off that little piece of tape to uncover the screw there was no screw there. so how else do i reset the ecu? i heard of disconnecting the battery but for how long? thanks guys
Old Aug 24, 2005 | 02:32 PM
NmexMAX's Avatar
dot dot dot ...
What year of cr do you have? Why would you want to reset the ECU anyway by d/cing it, and not getting any codes?
Old Aug 24, 2005 | 02:34 PM
99Automagic
The screw is a little ways inside that hole. You'll have to fish around, but be carefull, and be gentle. You can unhook the battery and it will reset the light, but whatever code you had before is still stored in the ecu. Half an hour should do it, but don't quote me.
domlcardio's Avatar
well to get codes, plus just to reset it. but i also want to see if there are any codes. i have a 99 max
Old Aug 24, 2005 | 02:35 PM
domlcardio's Avatar
oh i c. because the tape says something about idle adjustment but i guess its for that gear looking thing near the bottom. i ll take a look again
Old Aug 24, 2005 | 02:45 PM
domlcardio's Avatar
man that ecu looks funny. first of all there are no leds to get the code from its like either its a different one or something it looks weird.........oh oooops the check engine light gives codes. but anyways, if i turned the right screw isnt everything supposed to reset like the clock and radio?
Old Aug 24, 2005 | 02:51 PM
99Automagic
Here, read this thread.
http://forums.maxima.org/showthread.php?t=104931
This will show you how it's done.
Try reading all the stickies first. It's good to inform yourself on how everything works on your car before you start tinkering with it. I learned this lesson myself after breaking a few things.
Old Aug 24, 2005 | 02:53 PM
domlcardio's Avatar
u c i read that before but for some reason that big silver screw is not there. there s only some gear type thing in there that hole, but no screw.
Old Aug 24, 2005 | 02:54 PM
domlcardio's Avatar
oh i c. thanks man
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
220k+ A32
Sep 22, 2015 03:08 PM
Colossus
Sep 9, 2015 05:46 AM
