how to replace front sway bar bushings
Old 08-24-2005, 06:33 PM
SamMan23's Avatar
does anybody know how to do it?
how many bolts and where to take it apart?
and where can you get the ES endlinks? which ones?
Are the ES endlinks any good or should I get Nissan?
SamMan23 is offline
Old 08-24-2005, 06:48 PM
2 Da Max's Avatar
bushings? you mean the stabalizer end links? its not hard its a 17mm nut. just replace them from a partstore, they have grease and grease less links
2 Da Max is offline
Old 08-24-2005, 07:15 PM
Old enuf to pick his own gears
d00df00d's Avatar
ES bushings = polyurethane. Nissan bushings = rubber.
ES all the way.
d00df00d is offline
Old 08-24-2005, 08:54 PM
bhmax16's Avatar
He's talking about the sway bar bushings, not the endlinks. There are 2 of them, one for each side of the sway bar. They're REALLY easy to replace. Each mount has 2 bolts. Undo the bolts to the mounts, take them off along with the bushings. Grease the inside of each bushing and put them on the sway bar (after removing rust and whatever crap may be on there) then put the mounts back over them and tighten. DONE! Don't get me started on the control arm bushings though....THOSE are a pain in the a$$
bhmax16 is offline
Old 08-24-2005, 09:00 PM
nick's Avatar
look for write up in my sig
Nick.
nick is online now
Old 08-24-2005, 09:14 PM
maxS
when i replaced old once with oem/nissan bushings, they (new) looked like gum - kind of squashed out... oem no good???
Old 08-25-2005, 04:17 AM
nick's Avatar
OEM's don't give you rough and harsh ride, but the handling is just as good as the ES bushings.
those are easy and cheap to replace , so i don't mind throwing new bushings on there every 20K
Nick.
nick is online now
Old 08-25-2005, 07:28 AM
d00df00d's Avatar
Thanks. Silly mistake. Post edited. ^^
d00df00d is offline
Old 08-25-2005, 08:53 AM
UncleMax98's Avatar
Mine is at 120K. Do they go bad and require replacement? Should I replace the end links, too?
UncleMax98 is offline
Old 08-25-2005, 09:22 AM
gtr_rider's Avatar
http://www.courtesyparts.com/energys...on/maxima.html
gtr_rider is offline
Old 08-25-2005, 09:24 AM
nick's Avatar
yes , they go bad and should be replaced more often than you think
Nick.
nick is online now
Old 08-25-2005, 11:15 AM
Jatan's Avatar
Cheaper than Courtesy: http://www.suspension.com/nissancars.htm (half way down)
Jatan is offline
Old 08-25-2005, 12:46 PM
UncleMax98's Avatar
Thanks. I just ordered the sway bar bushing set (2 bushing + 4 grommets) total $11 plus $2 shipping from www.suspension.com.
kingw323
20
10-21-2015 08:36 AM
homeyclaus
09-03-2015 06:15 PM
Maxboy23
08-20-2015 09:33 AM
MaxStock
08-14-2015 10:03 PM
jerrod99_se-l
08-10-2015 12:07 AM
Quick Reply: how to replace front sway bar bushings
