Clean throttle body or not
That is one dirty throttle body. I just cleaned the TB on my max for the first time ever @ just over 120k miles and it wasnt THAT dirty. If I were you, i'll get up from my computer right now and clean it. You'll get smoother idles and better gas mileage.
How far up inside did you manage to clean?
I just did one at 118k, and it looked worse than that. my entire intake has a coating of black crap all over it. I just unbolted the tb and cleaned it that way, along with as far into the ntake as i could see. while youre at it, pull your iacv apart and clean it up.
clean that. i try to do mine every other oil change.
its an excuse to spend some time with the car.
sorry to jack the thread, but when i was doing the iacv, i remember the piece leading to the manifold had a thick thick layer of crap. i remember getting as much out as i could with a toothbrush, but would it be safe to spray tb cleaner inside there?
its an excuse to spend some time with the car.sorry to jack the thread, but when i was doing the iacv, i remember the piece leading to the manifold had a thick thick layer of crap. i remember getting as much out as i could with a toothbrush, but would it be safe to spray tb cleaner inside there?
No, I didnt change either gasket, lthough im sure some people would say you should. both of mine were in great shape, so i just cleaned them up and re-used them.
If youre just using carb and choke cleaner, or something that evaporates, its safe to spray it in there. Be careful though when youre cleaning the intake, you dont want all that **** falling down into the motor.
The best way to describe it is.....peppy. Before i cleaned it it had a split second lag from hitting the gas to the car responding, now its instantaneous. The only problem i have is when i first get in the car the throttle pedal sticks the first time i hit it. Im gonna go out there now and look at it, it might just be the cable, or maybe itll go away after a few weeks
I bought my car with 74k miles, I just hit 114k miles tonight. I cleaned my throttle body a few days ago for the first time, and I was kicking myself for not doing it earlier. it's worth it, get a can of gumout and go nuts.
To truelly clean out your throttle body you should pull the whole manifold off. Reason being is b/c after 100k miles your going to have gunk in the throttle body, IACV, and where the EGR Guide Tube meets the intake manifold. That black gunk AKA "CARBON" is everywhere. After doing this though your car should have smooth idling and may even get a little roar at WOT.
I think I might leave it til after I do the 5speed swap.. rather do that incase I have problems with the swap and think the TB is the cause
But Yes it needs a clean, I have a MEVI, mines a JDM car so it came from the factory with MEVI installed.. it has 240,000kms through it... how bad are they to pull apart?
220k+ A32
Sep 23, 2015 03:38 PM
97_GXE
Sep 15, 2015 06:47 AM
