Blinking air bag light
Old Aug 30, 2005 | 05:21 PM
wicked1044's Avatar
Who has had this happen? I'm going to check my manuel when I get bak home but for now I want to know whats going on. My battery was dead and I had to jump the car a few times, turning the key a lot and having all the lights on the dash come on. Now with the new battery in the light comes on when started, like normal, and then starts to blink and does not go off. Please help, Thanks...
Old Aug 30, 2005 | 05:31 PM
eLMo's Avatar
I found this in the Stickey's here
How to reset SRS(air bag) light
Open the driver's door. Note the rubber covered button located low on the B pillar, a button which is pressed by the door when the door is closed. This is the Driver's Door Switch (DDS).
Turn the ignition from OFF to ON. Press the DDS at least 5 times within 7 seconds after turning the ignition switch ON. Turn the ignition OFF. Close the driver's door. Start the engine.
If the airbag warning lamp is still on (or still flashing), there is a fault in the Supplemental Restraint System which must be diagnosed and repaired. This is a job for your local friendly Nissan dealer.
Old Aug 30, 2005 | 06:29 PM
wicked1044's Avatar
Cool, i'll give it o shot.. Thanks a lot!
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Sep 8, 2015 02:36 PM
sdotcarter
Sep 2, 2015 09:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
