KS bolt a bi_tch to loosen
Old Aug 31, 2005 | 08:55 AM
Noslen's Avatar
i'm using a 12mm and ratchet to loosen the KS bolt but it's so ****en tight!!!!! and ideas to how to loosen it?
Old Aug 31, 2005 | 08:59 AM
njmodi's Avatar
Do I get a tax break?
Just keep at it - you have a 12mm univ socket on there right?
Go drink a protein-shake and some spinach quiche and try again! it will break loose eventually.
Old Aug 31, 2005 | 09:07 AM
tomservo291's Avatar
What i did with ~ 14" of extensions and a universal joint and a shallow 12mm socket was fish the extension in there and seat the socket (have someone hold a flashlight so you can see in there, it's actually pretty easy to get the socket seated like this.)
hold it very still and pivot it as HIGH AS POSSIBLE! That's very important, it seems that it gets just enough angle that the u-joint will work. put the ratcher into the extension if it isnt already and yank on it real fast .. once it's loose it's very easy.
The hard part is getting the bolt back into the new knock sensor... luckily my girlfriends hands are small enough to fit in there and she got it in for me
Old Aug 31, 2005 | 09:31 AM
Noslen's Avatar
i'm still working at it. It's pissin me off!!!! AAAAAHHHHHHHHHH turn bi*ch, turn!!!
Old Aug 31, 2005 | 09:37 AM
THEJEFFERATOR's Avatar
i set the socket on the bolt with the ratchet attached, while holding the ratchet straight and steady, i used a long flathead screwdriver to pry between the ratchet and a thin metal bracket that was right in the perfect spot near the end of the ratchet(leverage is power). one quick snap and it came out with my fingers the rest of the way.
Old Aug 31, 2005 | 09:39 AM
Noslen's Avatar
thx, i'll try that, i'll be back in 10 mins, screw it, i'm bring the laptop outside
Old Aug 31, 2005 | 09:43 AM
NmexMAX's Avatar
dot dot dot ...
Stop being a WAB ...
Use the handle from a floor jack as a breaker bar I do that everytime.
Old Aug 31, 2005 | 09:58 AM
Noslen's Avatar
got the bolt off, woo hoo, but how do you take off the sensor from the harness?
and i heard a "beep" sound when i removed the old sensor, is that normal?
Old Aug 31, 2005 | 10:03 AM
Noslen's Avatar
never mind, got that working
Old Aug 31, 2005 | 10:28 AM
Noslen's Avatar
VVRRROOOOOMMMMM!!!! Damn, i really miss the car in its normal state!
thanks guys
Old Aug 31, 2005 | 02:45 PM
Shift_max power's Avatar
wd40????? should work
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
