dreaded code 0400 on a 99, egr flow problem
Old Sep 1, 2005 | 03:59 PM
edwardh1's Avatar
Any idea what the most common cause is? the egr valve on 99s looks almost inaccessible. Is this a common code/ I get one then it clears for a few months then comes back.
Is this a pattern/common failure in the Max?
Old Sep 1, 2005 | 04:12 PM
njmodi's Avatar
Do I get a tax break?
Common problem. The most likely cause is a clogged EGR port on the plenum and/or a clogged EGR guide tube. You can clean both out yourself if you are reasonably handy - since it involves pulling the plenum off the car. Get a Haynes manual (if you don't have one)...
Old Sep 2, 2005 | 03:47 AM
edwardh1's Avatar
any idea why it would be intermittant? that is get the light it goes away weeks later comes back a month later?
Old Sep 2, 2005 | 06:38 AM
njmodi's Avatar
The tube is probably partially clogged - so sometimes the flow detected is sufficient and sometimes not. Mine did the same thing. The light popped on, indicated P0400 (0302), I reset the ECU and the light didn't come back on at all. I had to pull the plenum for some other repairs, so cleaned out the EGR port and tube at that time.
sctludwig
Sep 1, 2022 01:32 PM
jwright36
Sep 8, 2015 11:45 AM
Maxboy23
Sep 4, 2015 06:04 PM
Justin Kroll
Sep 2, 2015 11:06 AM
