using 87 octane...
Old 09-01-2005, 05:08 PM
Albert's Avatar
using 87 octane...
what is the worse that can happen?
Albert is offline
Old 09-01-2005, 05:12 PM
s0ber's Avatar
your car will explode into tiny peices sending your limbs in different directions.
s0ber is offline
Old 09-01-2005, 05:13 PM
Kevlo for President
Kevlo911's Avatar
You save 3dollars and get worse MPG?
Kevlo911 is offline
Old 09-01-2005, 05:16 PM
wannaboostbad's Avatar
Yeah i wondered about going to regular til gas prices somewhat settled down, but i did the math and its just a 0.18 difference between 87 and 93. I just say stick with the 93 or whatever ur octane is. I also heard that going to 87 will retard ur timing, and give u s h i t t y throttle response.
wannaboostbad is offline
Old 09-01-2005, 05:18 PM
kcryan's Avatar
it will retard the timing, it will hurt power, it may hurt milage, id say give 89 a whirl if your interested in saving a few. it may not change much
kcryan is offline
Old 09-01-2005, 05:20 PM
goldtooth's Avatar
I will be hiding in 500 yards away and will be aiming the sniper at you at the gas pump. The moment you press any button other than Premium, you can be damned sure that my bullet will take out you and your car. The armor piercing bullets will finish you first and then take out your car by hitting the gas tank. Your car will then thank me.
Nah, Im just joking dude. Hope that scared you away from low octane rating.
goldtooth is offline
Old 09-01-2005, 05:26 PM
4banger69's Avatar
Don't cheap out
4banger69 is offline
Old 09-01-2005, 05:32 PM
DrTySOUFMaX23's Avatar
wtf?!?! hahaha.. "uhhh, we gotta man down here that got taken out by a
maxima.org sniper u copy that over? tsssshhhhed.. I copy,
tsssshhhhhed. trash the driver, save the max over,
tsssshhhhhed." Roger that!! tssssshhhhhhhed..
-sorry i was bored-
DrTySOUFMaX23 is offline
Old 09-01-2005, 06:25 PM
rome06's Avatar
-sorry i was bored-
ahahahahhahahahahaa
rome06 is offline
Old 09-01-2005, 06:29 PM
ArcticW's Avatar
PREMIUM OR DEATH !
I quote from the Laws of Hammurabi,concerning Maxima Gasoline and High Prices
(yup, they found King Tut's Max. That's one car they built a whole pyramid to protect )
If one shall gaze upon the gasoline giver,and sample of 87 octane is placed in the sacred temple of Maxima,then THOU SHALT BE PUT TO DEATH!
just playing , of course
ArcticW is offline
Old 09-01-2005, 06:36 PM
1 of few unmodded 4G Maxs
Wills98MaxSE's Avatar
http://forums.maxima.org/showpost.ph...65&postcount=8
Wills98MaxSE is offline
Old 09-01-2005, 06:57 PM
achebee4you's Avatar
i think its as big diff from 280 to 311 for 93
achebee4you is offline
Old 09-01-2005, 06:58 PM
i put 87, i hope it doesn mess anything up, i just dont hit the gas that hard and i use cruise control everywhere even on local roads in bfe, lol
Old 09-01-2005, 07:05 PM
mizmo21's Avatar
haha, there is no change but tiny gas milage, been using it since i bought my max in 98 never had a problem yet, runs brand new, if thats not enough proof nothing is, i dont race or go fast so maybe premium would help you there but theres little difference
mizmo21 is offline
Old 09-01-2005, 07:38 PM
Always sunny in philly
Nismotic's Avatar
nobody uses gasoline anymore. Vegetable Oil is where it's at.
Nismotic is offline
Old 09-01-2005, 08:13 PM
99Automagic
Would a substitue like I can't believe it's not butter spray work as well? It's less fattening and I'm trying to be health concious. WHat's good for me is good for my car.
Old 09-01-2005, 08:49 PM
Maxima Owner
MaximaSE96's Avatar
I converted my maxima to methane gas.......so i fill my tank up with my poop and it uses the methane content......instant HP gain....i think i am at 200 WHP NOW
MaximaSE96 is offline
Old 09-01-2005, 09:24 PM
PoKKi's Avatar
I was using 87...I actually got better mileage. But basically you'll notice a decline in performance.
PoKKi is offline
Old 09-01-2005, 09:35 PM
Bobo's Avatar
Buy 90 octane at 87 octane prices at Husky Oil if you have it there. I have been buying it for the last few months and the Max seems to like it, plus its 11 cents a litre cheaper than 91 or 92 octane.
Bobo is offline
Old 09-01-2005, 10:07 PM
tastey wheat
mendon99's Avatar
i cant even get 91 in my area, ive NEVER seen it, ever. its only 87, 89, or 93.
mendon99 is offline
Old 09-01-2005, 10:32 PM
DuMKuH's Avatar
Just like most of you said, this threads pops out every once in a while and I just don't see why should this question stand-the difference between super and regular stays appoximatly the same and you save like 2-3$ a tank. Just my .2
DuMKuH is offline
Old 09-01-2005, 10:50 PM
Maximaler Experte
Fork's Avatar
Originally Posted by Wills98MaxSE
Did you all miss this link? Couple points:
- Maxima's get on the average get 30mpg city/ 35 highway. Not bad for a 6 banger. Actually, it's pretty dang good.
- If you can't afford the premium gas, why own a Maxima?
- Putting in 87 will eventually destroy the engine. Because the engine is designed to run on a higher octane, it trys to compensate by changing the timing, and as a result, the engine runs hotter from the pings-misfires. It WILL damage your engine, over time. P e r i o d.
- If it's dire $$$, put in mid-range. Midrange is less harmful, but not great either.
- MATH TIME. With gas running $3.50-4 a gallon, remember, if your car gets poorer fuel economy, the savings might not be worth it. For example, if your Maxima gets 30mpg, you get ~500 miles on the tank (what I get). If putting in 87 octane nets you 430 miles, that's a 13% drop in fuel effiency. If premium 13% more in price, then yes, it's economical. If it's not, then you're actually wasting money buying a cheaper fuel.
"...The piston can overheat and knocking can and will occur. This knocking is caused by ignition of the gas/air mix in your cylinder before the spark of the spark plug. This causes temperature and pressure peaks that will melt your piston, crack your cylinder head, and drop one of your exhaust valves. You have heard about those abrupt deaths of air cooled engines..."
More info: http://www.msgroup.org/TIP037.html
There are hundreds of articles on this issue of octane misfiring.
Fork is offline
Old 09-01-2005, 10:52 PM
SLOW
Nealoc187's Avatar
I started putting 87 in my beater max a few months ago and have noticed no ill effects. I've even gone to the track with it and ran good times.
Nealoc187 is offline
Old 09-01-2005, 11:00 PM
l3ftonm3's Avatar
yah ive been running 87 for the past 2 weeks no ill effects the car just dosnt seem as peppy, but hey either 3.53 for 87 or 3.96 for 93 as of 2 hours ago I think ill take the 87.
l3ftonm3 is offline
Old 09-01-2005, 11:21 PM
Wisky97SE's Avatar
Towards the end of my ownership with the Maxima, I just put regular in and it drove perfectly fine. It wont really hurt anything, but you will lose performance and MPG, to be honest the engine in my maxima did not hesitate or ping.
Wisky97SE is offline
Old 09-01-2005, 11:38 PM
MystA RavE's Avatar
To get 91, fill half tank 89 and half tank 93 lol
MystA RavE is offline
Old 09-01-2005, 11:49 PM
optimus310's Avatar
How the hell you guys get 500 miles to teh tank?
I'm lucky if I get 350
optimus310 is offline
Old 09-02-2005, 04:44 AM
tastey wheat
mendon99's Avatar
350? how? man, what do you do to your car? i beat the crap out of my car and i still get over 400 mpt. are you auto?
mendon99 is offline
Old 09-02-2005, 06:15 AM
Bobo's Avatar
Good Canadian gas that doesn't contain alcohol like US gas. I have gotten over 550 miles to a tank 3 times and between 500 and 550 at least 15 times.
Bobo is offline
Old 09-02-2005, 06:27 AM
JClaw's Avatar
Driving like a grandma = good gas mileage.`
BTW putting 87 octane, after a while, will fukc up your knock sensor and fool it into retarding timing. There is a noticeable difference between normal timing and pulled timing, I measured it on the butt dyno (SAE corrected).
JClaw is offline
Old 09-02-2005, 06:28 AM
KCMaxima98's Avatar
The max does not get no 35 mpg . Even if you drove 55 mph and shifted at 2k rpm that would not happen.
KCMaxima98 is offline
Old 09-02-2005, 07:04 AM
Bobo's Avatar
I think he is referring to an Imperial gallon. So 35mpg to an Imperial gallon would translate to 29.17 to a US gallon. I consistently get 35mpg plus to an Imperial gallon on road trips. Why - Canadian gas is better, cruise control, and don't exceed 75mph!
Bobo is offline
Old 09-02-2005, 07:05 AM
Wisky97SE's Avatar
Ive always read that but I think its a misconception that it will hurt the knock sensor. The knock sensor is always working and sensing the octane rating, it senses the octane of the fuel you put in the car and the ECU adjusts the timing accordingly. By putting 87 octane in, no doubt your knock sensor (provided it is working correctly) will retard the timing to prevent knock but IIRC returning to premium fuel , the knock sensor will advance the tmiing.
Old 09-02-2005, 07:15 AM
KH3 by popular demand
maxgtr2000's Avatar
As Paris Hilton would say..that's hot. . Gas prices won't go down much, once supply comes back up the stations will have to make up for some profit loss for running out/people buying less.
maxgtr2000 is offline
Old 09-02-2005, 07:36 AM
PAY_ME96's Avatar
Since my KS is already fcuked up, will 87 make a difference now... I mean dang, the masses want to know...
PAY_ME96 is offline
Old 09-02-2005, 09:09 AM
99grnmaxgxe's Avatar
How do you say that Maximas get 35mpg? On the stealership's window sticker, it says that Maximas get 21 mpg in the city. I certainly don't get 35 mpg.
99grnmaxgxe is offline
Old 09-02-2005, 09:46 AM
Donating i30 Owner
HomerMAC's Avatar
i dont think ur knock knows what octane ur putting in .. nor can it sense what octane... it is cluelesss to octane it only senses the knocks.. and the knock wont retard timing just cause u put 87 ocatane.. it will retard teh timing even with 93 granted u have knocks.. the knock sensor cant sense the octane jsut the knocks.. the 87 give smore knocks... (popular belief.. that I follow as well) thus the ECU will change timing....
im jsut saying... incase im misinformed please let me know.. so i dont sound like an idiot at one of the meets.. = )
HomerMAC is offline
Old 09-02-2005, 09:53 AM
MidwestMaX1's Avatar
Alcohol is a type of fuel source too, ya know.. I heard if you dump a Bud Light in your Max it'll run forever.
MidwestMaX1 is offline
Old 09-02-2005, 09:58 AM
Maximoneypit
NCSU_MAX's Avatar
mythbusters says that you can add moth ***** to your 87 octane filled gas tank to bump the octane near 93
not sure about long term effects tho............
NCSU_MAX is offline
Old 09-02-2005, 10:11 AM
BigLou93SE's Avatar
Why not read four posts up and get the answer?
BigLou93SE is offline
Quick Reply: using 87 octane...
