oil pressure sensor
Old Sep 5, 2005 | 12:15 PM
diy_dreamer's Avatar
oil pressure sensor
First I want to thank everybody here . Me being a total newbie, I've already changed my brakes, cleaned my TB, changed my oil, and replaced both my axles (that pass side is a tough one). And thanks to Tom from NJ for doing my shocks!
Anyway, when I was replacing my axles, I broke off my oil pressure sensor. I bought a new one (from autozone) but no matter which socket I use to removed the old one, it doesn't fit. I've tried everything and can't get it off. Is it a special tool? How do I remove it and put the old one in there?
thanks
Old Sep 5, 2005 | 12:32 PM
Nealoc187's Avatar
SLOW
Use vice grips or channel locks.
Old Sep 5, 2005 | 01:29 PM
99Automagic
thanks
You're not such a noob if you did all those things on your own. Some people still bring their cars to a garage to do their spark plugs.
Old Sep 5, 2005 | 02:13 PM
just to prove that I really am a newbie...what's vice grips? What's channel locks? Can I go to sears and ask for them? Does anybody have a pic?
thanks
Old Sep 5, 2005 | 02:27 PM
njmodi's Avatar
Do I get a tax break?
Channel locks:
Vise Grips:
Old Sep 5, 2005 | 02:45 PM
Nealoc187's Avatar
SLOW
Yep you can get them at sears.
Old Sep 5, 2005 | 03:47 PM
96mAx2fast's Avatar
Im not sure if this is the same thing, but my oil pressure switch is leaking some oil. Its the little plug thing that is right next to the oil filter. Can someone tell me how much it is and where i can get it? Thanks..
Old Sep 5, 2005 | 03:57 PM
njmodi's Avatar
Yes thats the oil pressure sensor. Any parts store or dealer - $10 bucks or less.
Old Sep 5, 2005 | 04:00 PM
RA030726's Avatar
I'm nutty for Nissans
get an oil pressure switch socket. $7 at napa.
THT's Avatar
THT
Throbbing member
$6 at Autozone.
Old Sep 5, 2005 | 04:21 PM
RA030726's Avatar
<----------owned
Old Sep 5, 2005 | 06:21 PM
njmaxseltd's Avatar
Took 9 posts to get the right answer, the correct tool for the job which cost a lot less then a good set of channel locks.
Sometimes this place amazes me with intelligence.
Old Sep 5, 2005 | 07:34 PM
96mAx2fast's Avatar
6$.. what does it look like? How do i replace it?
Old Sep 5, 2005 | 07:38 PM
THT's Avatar
THT
Throbbing member
Just ask for an Oil pressure sensor and they'll know what it is. To replace, unplug the electrical harness and unscrew the old unit. Screw in the new unit and reconnect the plug. I suggest doing this while doing an oil change to minimize the mess.
Old Sep 5, 2005 | 09:21 PM
RA030726's Avatar
scary isnt it?
I was in the middle of removing mine, trying to use adjustible pliers as advised on motorvate. FUNK DAT! there is no way to properly remove and install the switch with out the socket, at least for me. So I had to go out and buy one. What a life saver.
gustavison
Oct 4, 2015 06:50 PM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
