weapon r coil over
Old May 27, 2001 | 12:48 AM
geomax's Avatar
i have had weapon r coilovers for a while but every time i turn it always goes snap crakkle pop and its annoying and also i feel like have a body in my trunk just bouncing everywere what can i do to prevent this.
Old May 27, 2001 | 12:43 PM
ikSardarG's Avatar
Are you familiar with the sounds that a body makes bouncing around in your trunk? Perhaps I should get a buddy of mine to lay in my trunk as corner at 30mph...
Anyways, check out your CV boots/joints. The boots are locates at under the car near your front wheels, and are rubber boots filled with grease and such... CV = Constant Velocity... Check that the boots are in good soft plyable condition, and that they are not torn... Also, I have heard when swapping springs that sometimes people get that knocking sound and have to go back and either align the spring in the seat better, or add some sort of foam peice to give it more of a seat to seat under and on top of... They sell em at like Pep Boys... Spring spacers I think...
Old May 27, 2001 | 12:51 PM
Nealoc187's Avatar
SLOW
bearing
there should be a gray and black donut shaped bearing that is intended to enable smooth and quiet turning of the wheels. if that bearing is destroyed, or worse yet, missing, you will get horrible noises from your coilover setup... at least i did with my GCs when i destroyed one of those bearings by not having it properly seated when i lowered the car off jacks once. you can purchase this bearing from nissan dealerships, its $20. its called the Strut Mount Bearing.
Old May 27, 2001 | 04:31 PM
1MAX2NV's Avatar
Go and buy some new struts. I suggest you get Koni.
Old May 27, 2001 | 09:22 PM
Gotrice4's Avatar
What's your experience with the Weapon-R coilovers? Are they worth getting? how's the ride and what negatives are you seeing? tell all your experiences with them...thanks.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
howardis
Dec 11, 2019 06:10 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
